Originally Posted by Xterra
I have a 2014 AI 3500 EXT and have some basic questions. My first question is a storage question. I keep it parked at my house under roof and I have it plugged in (30 amp) with the ac set at 80. I live in FL it's hot so I thought it would help to not heat up the inside so much. Should I turn the battery disconnect off while its plugged in at home and not in use?
No, leave it connected if you are plugged in to shore power. Honestly, I wouldn't leave it set at 80F. If it were me, if it's under a roof, I wouldn't worry about it and wold not leave the AC on unless you plan on using it and want to cool it down. The heat won't hurt it. I leave mine outside without a roof, and it gets very hot. Haven't had an issue in 7 years. I do cool it down when we plan on a trip to load it.
Driving questions. While driving my understanding is the house battery's will be charged enough to keep the ref running but once you stop, the house battery's will only keep ref going a few hours. Is this correct?
No. But how long it will run depends on which model refrigerator you have and the condition of the house batteries. I have a smaller one-it will run about a good 18 hours or more-and I still have the original 80amp hour twin battery setup that came with the rig when I bought it in 2011.
Also, you dont have to turn on the inverter while driving to do this do you? My understanding is the inverter works the outlets marked with blue for small items like cell ph charging etc.
Correct. You don't need the inverter unless you want to use the 120ac outlets or TV while on battery power only.
Solar question. Do you turn on the solar panel or is always charging the house battery's when it can? Thanks for helping me in advance.
Unfortunately, the cheap solar controller Airstream uses doesn't do much in my opinion. I guess it's better than nothing, but not by much. You don't have to turn it on. My recommendation is to replace that thing asap with a MPPT controller such as the Victron 100/30. Then you actually will be getting some real charge out of the panels.
