Old 08-31-2020, 01:24 PM   #1
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Talking Gen oil change
Had to share my pic of summer fun......generator oil change......at least heat index only about 100
‘20 IS 19’ TB, 2wd
Pensacola,FL
Beemerman is offline   Reply With Quote
Old 08-31-2020, 01:28 PM   #2
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Sorry for sideways pic....have no idea how to correct ��
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 09-01-2020, 06:33 AM   #3
Luckysnuck's Avatar
Liberty Township , Ohio
You now have me wondering; at how many hours (unsure if an hour timer is on the Onan?) or period of time is it recommended that the generator oil be changed?
Thanks in advance.
Luckysnuck is offline   Reply With Quote
Old 09-01-2020, 08:41 AM   #4
Mollysdad's Avatar
I like those blocks!
(BTW, saved your image, opened it, rotated, and resized it by a tiny amount. 'voila)
Old 09-02-2020, 06:13 AM   #5
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Thumbs up Gen hours
Thanks Mollysdad !!!! I corrected the pic, but then I couldn’t upload it correctly......Ima analog guy in a digital world......😔
Gen hours: On the newer “C-zone” controller, the “Generator” tab will show accumulated time in small numbers on the right. I think Onan wants you to check oil level every 20 hours.....not sure about oil change. As a new unit, I changed @ 20 hours, and again now at 30 hours; planning to change every 20 hours; probably overkill, but I believe in pampering the little (220cc) air cooled engine ‼️
Without starting a dreaded oil thread, I went to straight 30w HD at 30 hours, with a few more months of unreal heat.....we use gen alot for air conditioning
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 09-03-2020, 03:18 PM   #6
Amg
2016 Interstate Lounge Ext
Pittsburgh , Pennsylvania
I am on my third airstream. Onan manual says to change oil first time at 20 hours and thereafter every 150 hours. I am not mechanically inclined at all and I always go to a nearby Cummins Onan facility for the change. I questioned them about the frequency and they said the reason for first early oil change is to catch the machining debris when new. There is no oil filter. They confirmed no need to change until 150 hours thereafter. I am sure everybody knows the unit takes a small amount of oil and the oil sensor will shut engine down if too much or too little oil. There is little room for error. That with the difficulty of getting to the area to fill the oil makes putting in the right amount is more difficult. I have put thousands of hours on my Onan units and really have had no problems
Amg is offline   Reply With Quote
Old 09-03-2020, 09:38 PM   #7
TahoeStream'n
subfan1's Avatar
2019 23' International
La Habra , California
Hi how are you liking your 19? Any information you can provide will be helpful to us.
2018 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 10-02-2020, 12:07 AM   #8
2019 ​Interstate Nineteen
Chula Vista , California
As per the manual for the 2020 AI 19, first change at 20 hrs, second and subsequent every 100 hrs.
gatchason is offline   Reply With Quote
Old 10-02-2020, 04:18 AM   #9
Love the home-made ramps - they look oh-so-familiar.
But is that a dually on a non-dually ramp? Is that do-able?
We had a discussion a few years ago about DIY ramps and IIRC someone mentioned that it would be a hassle to make them as wide as they would need to be for the Sprinter's rear wheels.
Old 10-03-2020, 08:27 AM   #10
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Talking I 19 Singles Ramp
I’m sure I copied design from you (?) !!!!! This is my 19’ TB......fits nicely on these ramps, dualies would need wider dimension.....
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 07-10-2021, 06:49 PM   #11
Lucedale , Mississippi
How do you check the oil on 2018 generator? Pictures if possible please
MamaG is offline   Reply With Quote
Old 07-11-2021, 08:39 AM   #12
Rig Rat's Avatar
2015 Interstate Ext. Coach
Columbus , Ohio
There are several videos on youtube, here's one;
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
AI Propane Gen Set Oil Pressure issue Rig Rat Sprinter and B-van Forum 15 07-19-2018 07:32 PM
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Anyone using Synthetic Oil in Honda Gen ? 2dabeach Generators & Solar Power 10 11-23-2010 05:12 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Should I change my oil? Turtle Mechanics Corner - Engines, Transmission & More... 18 07-07-2004 12:18 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
