Old 08-29-2020, 01:18 PM   #1
Leesburg , Virginia
Fusion IN-801
Having issues with the infotainment system:
1) It doesn’t locate any satellites (thinks I’m in Miami??)
2). Speakers on passenger side have no sound
It is a new, recently installed radio. Our AI was in storage (plugged in) prior to having new radio installed. Installation while having minor body work repairs, but installation really is connecting the wiring harness. Any suggestions for trouble shooting? Thanks.
fstieff is offline   Reply With Quote
Old 08-29-2020, 03:00 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
There should be a balance adjustment somewhere in the menus on the Fusion. It could be maladjusted.
As for the satellite, no idea.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 09-05-2020, 09:58 AM   #3
2017 Interstate Grand Tour Ext
Houston , Texas
Sometimes, after a few days of non use, my Fusion fails to find satellites. A quick fix that almost always works is to turn of the satellite mode (a check box) and put in "simulator mode". When you put back in GPS mode, it finds satellites right away.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 09-06-2020, 07:08 AM   #4
GoingPhishin's Avatar
Castle Rock , Colorado
The fusion is not a good product.
You have to restart the system. See this thread
https://www.airforums.com/forums/sho...d.php?t=200310
GoingPhishin is offline   Reply With Quote
Old 09-06-2020, 08:03 AM   #5
Houston , Texas
If the trick I suggested doesn't work, then trying to powercycle with the on/off button might work. However I've found sometimes I have to turn off/on the entire house power button (the rocker switch near the slide door). It depends on how your GT is wired (mine is 2017) and varies from year to year. In worst case, you can do a "factory reset" from the Fusion screen; you will lose stored addresses, but not any updated maps.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
Painting over krylon fusion HiJoeSilver Upholstery, Blinds, Walls & Interior Finishes 3 06-26-2015 11:00 AM
Vintage Fusion - the story of our '69 AS Remodel monah 1959-69 Tradewind 255 09-08-2011 10:40 AM
Krylon Fusion Paint? Roadrunner General Interior Topics 24 11-18-2009 11:32 AM
Fusion for Plastic 76sovereign Sinks, Showers & Toilets 11 09-05-2008 01:15 PM
Krylon "fusion" stuart1 Plumbing - Systems & Fixtures 2 06-24-2003 08:36 PM
