Old 07-13-2018, 07:07 AM   #1
2017 Interstate Grand Tour Ext
Dayton , Montana
Fusion 3.7 update and map fix
I continue to use the Fusion software update site for latest updates.
https://www.fusionentertainment.com/...upport/updates
Have the Fusion system format a blank usb drive. Under settings software update.
Software Version: 3.70
VIM Version: 2.90
Installation Instructructions
Upgrading the RV-IN801 will require a SD card or USB flash drive with at least 500 MB of free space. The update
process includes two parts: Updatng VIM and Updatng system.
Warning: During the update process, do not power down the RV-IN801.
Updatng VIM:
1. Create a folder named “Garmin” (case sensitve) under root directory of the SD card or USB flash drive.
2. Create a folder named “Update” (case sensi ve) under “Garmin” that was created in step 1.
3. Copy all three (3) files under “Vim_Update” into “Garmin\Update\” on the SD card or USB flash drive.
4. Eject the SD card or USB flash drive from the computer and plug it into the RV-IN801.
5. A dialog will pop up on the RV-IN801 for updatng. Follow the on-screen instructons to apply the update.
6. After the update finishes, eject the SD card or USB flash drive from the RV-IN801 proceed to update system.
Updatng System:
1. Delete all files under “Garmin\Update\” on the SD card or USB flash drive.
2. Copy “B248800.update” into “Garmin\Update\”.
3. Eject the SD card or USB flash drive from the computer and plug it into the RV-IN801.
4. A dialog will pop up on the RV-IN801 for upda ng. Follow the on-screen instruc ons to apply the update.
5. After the RV-IN801 finishes rebootng, the update process has finished.
Changelog
3.70
Fix map unlock issue on map update. Bug fixes.
Now the map update will load.
Pez Vela is offline   Reply With Quote
Old 07-14-2018, 11:01 AM   #2
sheakev's Avatar
Madison , WISCONSIN
Thanks for letting us know there was an update. I had gotten the maps to load before but now I have everything up to date.
Kevin N9JKP
sheakev is offline   Reply With Quote
Old 07-15-2018, 12:21 AM   #3
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Changelog
3.70
PEZVELA, Thank you. I been holding off on updates due to everyone having problems, but will try this one soon. Thanks again. I hope works.
Alex AVI is offline   Reply With Quote
Old 07-24-2018, 10:54 AM   #4
Colorado Springs , Colorado
Thanks! I was eventually able to get up to 3.6 with 2018 maps after much gnashing of teeth, clicking of heels, and random cosmic ray interactions.
Now I have to ask myself if I want to update to 3.7 .... it seems like it might prevent future "can't unlock maps" issues if I do, but...
blyon3 is offline   Reply With Quote
Old 07-24-2018, 11:27 AM   #5
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Doing the 3.7 update tonight...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-24-2018, 08:02 PM   #6
wachuko's Avatar
Orlando , Florida
Done!
Safe travels!
Wachuko
WBCCI #26769
Old 08-25-2018, 04:36 PM   #7
Gallatin Gateway , Montana
3.7 update worked with no issues; total time to update took about 10-15 minutes
bob323 is offline   Reply With Quote
Old 08-26-2018, 06:57 AM   #8
Houston , Texas
I successfully updated to 3.70 and 2018.20. Used a 32GB card previously formatted in a camera, Garmin Express, and a Mac laptop. The only hitch was getting the "Can't unlock maps" message after the system update step. Removed and reinserted card, but it only offered to update my system again. I went to the Settings / Installed Maps area and unchecked/rechecked the 2016 map. Immediately it said "Found New Maps" and offered to update. The update took a LONG time (consistent with the size of the map data) and finally finished successfully.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 08-27-2018, 08:48 AM   #9
Leigh & Bettie, I've updated to 3.7 but my maps are 2016.2. If I might ask, how did you update the map data - did you use FusionExpress and download the Map data which appears to be a bunch of zip files. I'm downloading from FusionExpress now but am not sure whether I need to unzip the files or not? Perhaps at the end of the download it'll tell me. Thx.
Old 08-28-2018, 06:43 AM   #10
Houston , Texas
I think you mean GarminExpress? You don't unZip any files; the update process handles that. I followed the recommended process, and it almost worked. I had to kickstart one part. The steps below are from memory and may not be exact.
  1. Download GarminExpress from the Garmin site to my (MacBook) laptop.
  2. Put SD card in Fusion and choose "Create Card" on Setup menu.
  3. Run GarminExpress on my laptop
  4. Insert prepared SD card into my laptop
  5. "Add Device" in GarminExpress
  6. GE recognized the Fusion codes on the card and added the device
  7. Downloaded the install package including software update and maps. Took about an hour.
  8. Took card back to Fusion and inserted it
  9. On Setup menu choose Update
  10. Proceeded to let it update the software. An R2D2 figure appears on the screen for a few minutes, the system reboots, and indicates it is now at level 3.70
  11. I can't remember if I initiated a map update, or if Fusion prompted me. But when the update started, I got the "Can't unlock maps" error.
  12. I tried removing/inserting the card, same result.
  13. I went to the Setup screen and under "Installed Maps" I unchecked and rechecked the 2016 map. The system immediately informed me there is a map update available and asked to proceed.
  14. When it started to update, R2D2 came back and the message read "Updating System" (not maps). It took a very long time, I wondered if it was hung up. But this is consistent with the large size of the data files containing the maps.
  15. When it finished and rebooted I was at 2018 maps.
Good luck.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
Old 08-29-2018, 05:57 AM   #11
Thank you. The process, as you described, worked like a charm! As I had already updated to 3.7 (which fixed the "Can't unlock maps" error), the map update worked without any errors or intervention but, as you stated, it took a long time - probably about an hour plus/minus! Again, thanks for your help.
Old 08-30-2018, 10:37 PM   #12
SWH
2021 Interstate 24GT
Cordova , Tennessee
So frustrating as I was excited to update to 3.7 to overcome the can’t unlock maps error, but alas mine won’t even update the software- it immediately gives me the can’t unlock maps error when I plug in the USB stick with new software and maps. I’m stuck at 3.5.
SWH is offline   Reply With Quote
Old 08-31-2018, 11:39 PM   #13
Follow these instructions carefully to update to 3.7 (maps will be updated in next step below). https://www.fusionentertainment.com/...upport/updates
After successfully updating to 3.7, insert a blank card/memory stick into your Fusion head unit, select Update in the menu and press 'Create card', take the card/stick to your computer, log into GarminExpress, insert your card/memory stick into your computer and follow GarminEpresd instructions by loading everything available onto your card/stick. Then take your card/stick back to your head unit, insert it and select Update in the menu and follow the prompts. It'll update the maps (takes about an hour plus/minus) and it'll give you an error code when finished indicating that not all updates were successful (reason being that you've already updated to 3.7 via previous step).
Good luck.
Old 09-01-2018, 08:06 AM   #14
Houston , Texas
Another tick to try: with the SD card inserted, go to the Setup menu for navigation. Look for the Installed Maps check box. Uncheck your current map (2016) and recheck it. At that point, I got a message saying new maps were available, do I want to update. It worked at that point.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
Old 09-06-2018, 02:12 PM   #15
SWH
Cordova , Tennessee
Thanks for replies. After doing all the crazy tricks recommended here and on another thread, I got it all updated! Hopefully next time won’t be so difficult.
Old 09-18-2020, 02:42 PM   #16
wachuko's Avatar
Orlando , Florida
Updated again...
ID:	378938   Click image for larger version
Safe travels!
Wachuko
WBCCI #26769
Fusion - Map Updates? SWH Sprinter and B-van Forum 0 08-28-2017 08:01 PM
Garmin Map update in DNX7190HD Boxster1971 Sprinter and B-van Forum 38 08-02-2017 05:39 PM
2017 Interstate w/ Fusion infotainment system - update to v2.8 FlyFishinRVr Sprinter and B-van Forum 19 02-28-2017 03:46 PM
Fusion of Classic and Technology tsunami On The Road... 0 12-14-2016 04:11 AM
