Originally Posted by Charleston40
I have a 2017 Airstream Interstate. I have a fuse issue that is stumping me. The 20 AMP fuse title GFCI is tripped. The only time I can reset it is when when the 30 AMP Main fuse is flipped off. Any help is appreciated!
As far as I know you have 3 separate circuits for the GFCI breaker: Gally area under the cabinet, below the rear cup holder on on the passenger side and the outside outlet. Assume you have made sure nothing is plugged into those outlets and causing an issue then you may have a bad breaker or some wiring issue.
