Old 04-22-2024, 08:52 AM   #1
2011 Interstate Coach
Parkville , Missouri
Fuse for macerator pump
I am trying to drain my gray water and the pump won't come on. I'm assuming it is the fuse because it has been working. Where can I find that fuse? Is there a fuse map somewhere? Thanks!
JimWill52 is offline   Reply With Quote
Old 04-22-2024, 09:42 AM   #2
Found it!
I found the fuses. Thanks.
Old 04-22-2024, 02:50 PM   #3
jmahone's Avatar
2016 Interstate Lounge Ext
Annapolis , Maryland
Glad you found the fuse location. You may find you blow them more than just once in awhile. You might consider resettable fuses for the macerator pump, because many folks' experience is that you will run through a bunch of fuses.
Check the other macerator thread recently posted that talks about this and the use of the turn screw for the impeller to manually free blockages.
jmahone is offline   Reply With Quote
Macerator fuse location CavemanB Sprinter and B-van Forum 15 07-09-2023 03:39 PM
Macerator fuse Jpierce General Repair Forum 2 05-12-2022 07:54 AM
Macerator pump blowing fuse Mansderm161 Sprinter and B-van Forum 17 04-18-2022 01:40 PM
Macerator pump fuse blown. Prairie Sprinter and B-van Forum 29 09-07-2021 05:52 AM
Fuse for Macerator csb333 Electrical - Systems, Generators, Batteries & Solar 0 06-04-2020 09:43 PM
