Old 07-27-2020, 05:18 AM   #1
morley8000's Avatar
2022 Interstate 24GL
Denver , North Carolina
Flat chassis battery
My new 2021 interstate battery is flat. It’s only stood for a week. I’m moving house and trying to get it started. If it’s plugged into shore power will the chassis Battery charge.?
morley8000 is offline   Reply With Quote
Old 07-27-2020, 11:18 AM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
It should if the rather poor battery manager that Airstream installs works properly. The battery manager should connect the Magnum inverter/charger through to the chassis battery.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-27-2020, 11:27 AM   #3
2013 Interstate Coach
Waterloo , Iowa
I think somebody posted that the Airstream system (BIM? Magnum?) would not charge a completely dead battery and that you had to hook up a conventional charger to get it partially charged.
Titus is offline   Reply With Quote
Old 07-27-2020, 11:45 AM   #4
Contributing Member
Pahaska's Avatar
I posted that. If just the chassis battery is flat and the coach batteries are still charged, then the Magnum would charge the coach batteries. If the battery manager works correctly, it should also charge the chassis battery.
Becaus the battery manager Airstream installs is not very good, many of us have switched to a Blue Sea ACR that works much better.
John W. Irwin
WBCCI #9632
Old 07-27-2020, 05:06 PM   #5
morley8000's Avatar
Thanks everybody.
I went and bought a trickle charger( the other 4 I own are at the new house).
And it bought it up to about 9 volts then the Bim kicked in. I called mercedes. They committed 5 times to send someone and no one turned up. Got it going at lunch time today. All through the night the light and wipers were going with no way to turn off. Even disconnecting chassis battery made no difference
Extending battery life by connecting to chassis battery Tronadora Sprinter and B-van Forum 0 06-09-2019 02:53 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
2004 Land Yacht Chassis Battery? RAG Land Yacht/Legacy Motorhomes 11 02-01-2012 07:19 AM
Chassis/House Battery Charging 4 Motorhomes Jim Tyrney Airstream Motorhome Forums 41 03-11-2011 06:50 PM
Charging Chassis Battery guy99 Mechanics Corner - Engines, Transmission & More... 3 11-17-2005 11:55 AM
