Old 12-21-2019, 09:22 PM   #1
ScottP's Avatar
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
Flashing inverter light (Multiplex primary panel) inop Inverter ...
Hola ~
Any troubleshooting thoughts please?
Symptoms:
Occasionally turns itself on (the inverter does or “did” last week).
Now, zero functionality with inverter features/function. But we do have a flashing inverter light with no functionality.
Will usually allow me to turn it off successfully.
Circuit breakers are NOT tripped.
AC plugs do not work, not TV, VCR or other.
Thanks, Smiles
ScottP is offline   Reply With Quote
Old 12-22-2019, 05:38 AM   #2
Auburn , Georgia
Have you checked the small 5 amp circuit breaker on top of the magnum inverter? It controls all the plugs you have no power on.
GETRIDAONE is offline   Reply With Quote
Old 12-22-2019, 08:49 PM   #3
ScottP's Avatar
Thanks - will check that.
Old 12-23-2019, 08:14 AM   #4
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
There is a terminal fuse at the battery, under a red cap if I remember correctly.
Here is a thread on my personal battle with that particular fuse..
http://www.airforums.com/forums/showthread.php?t=184323
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 12-23-2019, 09:24 AM   #5
After spending our entire warranty period including a factory visit complaining about power issues, they finally replaced our inverter 2 weeks before warranty was done. (2014.5 interstate ext). All problems solved. Now to unlearn all the gymnastics we were given re GFI, power cord replacements, not able to run tv unless plugged in, etc.
camlivy is offline   Reply With Quote
Old 12-29-2019, 06:57 PM   #6
ScottP's Avatar
Embarrassed to ask, but where is the inverter on a 2018 ASI lounge?
Old 12-29-2019, 07:29 PM   #7
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Under the roadside jackknife chair. Behind the fuse panel. You have to remove that jackknife chair to physically access the Magnum. There is a ventilation screen under the chair. You can get some access by unscrewing the fuse panel board, but it is very limited by the wiring in my AI.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 12-29-2019, 07:49 PM   #8
ScottP's Avatar
Thank You
Old 12-29-2019, 08:37 PM   #9
Contributing Member
Pahaska's Avatar
Should have mentioned that there is an access hole in the ventilation screen that will allow you to reset the circuit breaker on the Magnum.
John W. Irwin
WBCCI #9632
Multiplex Control Panel + Blue Sea 7622 ScottP Sprinter and B-van Forum 6 11-02-2019 11:54 AM
Lights flashing when inverter ON wtdogg Batteries, Univolts, Converters & Inverters 11 10-19-2015 07:14 PM
title / park in NC, but primary home in GA Youma Title, VIN & Registration 5 07-19-2012 02:06 AM
Full timing and your primary residence Kman Full-Timing, Winter Living & Workamping 6 02-01-2011 07:38 PM
