Old 10-02-2023, 04:34 PM   #1
X , Florida
Firefly Eclipse module and E1
2023 I19 E1
Just put in the firefly eclipse module which worked right out of the box after updating with the supplied software. I did have to go into the “hidden” floor plan to reenable the shades and lights. I noticed another option labeled “Volta battery” and selected that which brought up an interface within the electrical tab which displays the Volta battery life and inverter controls (from within the firefly touchscreen). However they seem to be nonfunctioning—the buttons do not function and the meter just blinks blue and white. This feature was not present when I took delivery but am curious if anyone else has it functioning.
Also, I noticed that after the install / update my power source will state 15/20/30 amp shore power when the inverter is turned on. I *think* it use to say inverter and am wondering if anyone can confirm or compare. Everything seems to work well regardless.
Thanks.
ID:	437431   Click image for larger version
denial is offline   Reply With Quote
Old 10-02-2023, 09:38 PM   #2
X , Florida
firefly eclipse *vega* module
also, fixed pictures:
Duo-Therm comfort control module Gavin Winter Living 3 08-16-2009 07:09 PM
Looking for Control Module-Coleman Delta TX DataMover Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2009 03:48 PM
Cruise control module bkahler Mechanics Corner - Engines, Transmission & More... 2 01-10-2009 08:16 PM
ignition module will Classic Motorhomes 6 10-18-2006 09:48 PM
Hi Perf Module ALANSD Mechanics Corner - Engines, Transmission & More... 0 05-13-2002 08:03 AM
