Old 03-31-2021, 04:11 PM   #1
2015 Interstate Ext. Coach
Walnut Grove , Missouri
Fiamma awning control unit
I have a 2015 Grand Tour ext Mercedes sprinter and it has this Fiamma awning, every time I extend it, the slightest breeze causes it to retract. According to its manual there is a control unit where you can adjust the sensitivity of the seismic sensor. Simple enough to do if you could just find it. Is there anyone who knows where itís located?
Dribyks is offline   Reply With Quote
Old 03-31-2021, 04:47 PM   #2
Libertyville , Illinois
Itís located in the space between the interior ceiling and the van roof in the large rear overhead storage area. Need to remove 8 - 10 screws to access
Schmitte is offline   Reply With Quote
Old 03-31-2021, 04:51 PM   #3
Thanks so much, I’ll check it out
Old 03-31-2021, 07:44 PM   #4
Rig Rat's Avatar
Columbus , Ohio
In our 15 lounge the awning adjustment is found behind the control panel. Remove the screws and slide the panel front to the side.
Behind several wires you should be able to see the sticker on the black Fiamma control unit.
Take the screw out of the top and look at the back of it for the little white dial. It should be pointing to number five, which is the factory default setting.
Moving the arrow to a higher number makes the sensor less sensitive to wind. In this picture you can see I set ours to number seven.
ID:	392109   Click image for larger version
ID:	392111   Click image for larger version
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
Old 04-01-2021, 11:26 AM   #5
Thank you, that’s where it was.
Old 04-16-2021, 01:50 PM   #6
Traverse City , Michigan
Ok, so on my 2016 GT I have pulled the gauge cluster and it isnít there (suspect that is when it is a Lounge), and I pulled most of the screws in the back overhead compartment- enough to pull it down in front and nothing up there either.
Next guess? Maybe passenger seat base?
Heckler56 is offline   Reply With Quote
Fiamma Awning Wiring Issue Bikerbill Sprinter and B-van Forum 21 07-06-2018 11:35 AM
Fiamma Awning repair, Texas WillieJ Sprinter and B-van Forum 6 05-03-2017 07:49 AM
fiamma awning jennian Sprinter and B-van Forum 3 06-26-2016 07:03 AM
cant find control unit for Awning kwhatley Sprinter and B-van Forum 3 06-16-2015 07:20 PM
Location of Control Unit for Fiamma Awning for 2014 Ext? Kwils25 Sprinter and B-van Forum 10 08-16-2014 08:55 AM
