Old 05-21-2020, 01:01 PM   #1
TX-Newbie's Avatar
2018 Interstate Lounge Ext
AUSTIN , TX
Factory horn replacement
Hey all
Trying to replace factory with the PIAA dual superior bass horn. Attached are some images and a couple questions are
- it doesn't show I need a relay.. Correct?
- what do I need to do with the remaining negative wire (green)
First test didn't work.
Thoughts please
Thx
ErnyClick image for larger version
ID:	368437Click image for larger version
ID:	368438Click image for larger version
TX-Newbie is offline   Reply With Quote
Old 05-22-2020, 05:37 AM   #2
Libertyville , Illinois
Hi,
I installed these horns a few weeks ago using a kit from agile off-road which included a mounting bracket and wiring harness. I can confirm no additional relay is needed
If you split the positive (brown) wire and run a lead to each positive terminal on the horns Then do the same with the negative terminals to the green wire, they should work
Schmitte is offline   Reply With Quote
Old 05-23-2020, 12:13 PM   #3
TX-Newbie's Avatar
AUSTIN , TX
Originally Posted by Schmitte View Post
Hi,
Hmm. It's wired it that way and nothing. Interesting. I might need to check the relay to make sure it didn't get blown.
Thank you though
Old 05-23-2020, 05:16 PM   #4
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
TX-Newbie, Hope you get your problems solved soon with a minimum of fuss. I've been considering a horn upgrade so I'll be curious to see what you have to say. I like the idea of the Agile Off Road horn kit - particularly if it includes wiring to make the installation easier.
I haven't taken time to understand how to remove the grill. Any comments on that would be appreciated.
ON EDIT: just watched a very short YouTube video on grill removal. Looks like several screws at/near the top edge of the grill, then several spring latches/fingers near the bottom edge of the grill. Is that correct? Hmmm.... ours is a 2010 Interstate, yours is newer and may be different.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 05-24-2020, 01:28 AM   #5
2015 Interstate Ext. Coach
Lake Mary , Florida
Four years ago I bought a simple 15-bucks bass horn in local store, and simply connected it to factory horn wires, neutral and positive. From then and on I can scare any pedestrian with two-tone scream )))
Mr. B is offline   Reply With Quote
Old 05-24-2020, 09:19 AM   #6
TX-Newbie's Avatar
AUSTIN , TX
Hey all
I had some loose wires and now it works with no problem. Sounds much better than stock.
I would follow what @schmitte did though which is get it from agile so you get the bracket and wires. Will make it much easier
Thanks all for the help
Old 06-03-2020, 09:30 AM   #7
Luckysnuck's Avatar
Liberty Township , Ohio
Can anyone tell me if it's workable to (for a lack of a better term) "lay" the wiring for the PIAA Superior Bass Horn Kit on top of the MB Sprinter OEM horn wiring in my 2018 AIGT?
I've ordered the Agile Horn Kit for Sprinter 2007-2018 from Agile Off Road and I am wanting to have both my original OEM horn and the new PIAA Superior Bass Horn be operable.
Any input would be appreciated.
Thanks!
Luckysnuck is offline   Reply With Quote
Old 06-04-2020, 08:44 AM   #8
TX-Newbie's Avatar
AUSTIN , TX
Thanks!
Hey Lucky,
You don't want to do that. It clearly states in the instructions that you don't want to Piggyback the horns. The kit has two frequency horns and sounds really good.
Any reason you want to keep the OEM?
Old 06-04-2020, 08:50 AM   #9
Luckysnuck's Avatar
I just thought that two sets might sound better (stronger) than one; thanks for the advice.
Old 10-26-2020, 09:34 AM   #10
Luckysnuck's Avatar
OEM Horn Replacement ~ Goodbye Circus Clown-Car "Beep-Beep"
Finally got around to replacing the laughable (sorry Airstream/MB) OEM horn in my 2018 AIGT Ext and was surprised how easy it was. The only intrusive maneuver was drilling a few small holes for the duel horn mounting bracket, zip-tie placement and a slightly larger hole to string the wiring harness thru. I was mostly intimidated by the grill removal and replacement, but that was super easy.
Most importantly this dual horn set-up is loud and impressive (not obnoxious).
Thank you Agile Off Road for an excellent OEM horn alternative.
"Agile Horn Kit for Sprinter 2007-2018"
Old 10-26-2020, 10:09 AM   #11
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Looks good. We'll stay with the European "meep meep" horn for now. Reminds us of old Road Runner cartoons, and we get a laugh out of it.
Old 10-26-2020, 05:25 PM   #12
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Installation looks good. Unfortunately, they’re back ordered for now. Like so many other parts out there.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 11-07-2020, 07:12 PM   #13
2017 Interstate Grand Tour Ext
san diego , California
Horn replacement
The pic is sideways! I removed the OEM horn. The two PIAA horns are wired in parallel. The two wires are connected to the original cable and make no connection to the chassis. I replaced the original horn bolt with a longer one so that I could place a few washers to move the horn forward. I mounted the second horn by drilling a bolt hole in the plastic shroud.
I used a push pin pliers to remove the push pin center posts. The pins were still difficult to move/remove until I used some silicone lubricant.
It was good to have seen previous comments regarding removing the grill.
CorkWins is offline   Reply With Quote
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
20 Minute Horn at JC Factory in the '70's Carrma Airstream History 9 12-02-2016 04:48 PM
Re: Horn 2nd query Orland Dewey General Motorhome Topics 14 07-11-2003 02:19 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
