Originally Posted by Tronadora
For those that might want extra ground clearance on a 2WD chassis. Advanced RV is using all Mercedes parts to jack it up. Here's the YouTube video link.
They say 3.5" higher... is that how much higher the Airstream is on their AWD version?
TRONADORA - Per 2018 MB 4x4 specsheel - "Body lifted by 10 cm (3.9 in) at the front and 7.5 cm (3 in) at the rear"
I wouldn't mind lifting my 2wd AI but I also like to plus+ size the tires/wheels to Alcoa 19.5" .However, I don't think there's enough clearance to accommodate +3.5 wheels and tires (even if lowering profile of tires). Besides, the 19.5 is 8-lug vs. 6-lug for 16, and I hate wheel adapters, had issues with them before on pickups.
I watched the vid. I understand the owner's need for clearance. Yes, it saves 300-lbs and all that mention of chassis efficiency, effect on mileage, etc etc. But to go through all that work and not get 4WD is IMHO going ALL OUT on a build and stopping at 99%. Obviously if the guy can afford an ARV, he has the money to build whatever comes to mind. So why get all the MB 4WD lift parts and not have the drivetrain? It can't be about the money or fuel economy. Besides, even with all the confidence I have with ARV builds, I would rather get my 4x4, VB Air, and EPA Hydraulic levelers (if at all possible) straight from MB factory.
Then there's the unavoidable questions from interested or lookie-loo folks - "So how does your rig perform off road and snow?" So his answer could be "Ummm, it only looks like a $300,000 off roader but it isn't capable." This is a conversation I may be too embarrassed to have, especially if the one asking has a cheaper AI 4x4.
