Old 09-15-2018, 11:24 PM   #21
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Have since driven 500 miles, 1 week testing, hooked up 24x7 running A/C - all good. Good enough for me, so routed the new cable notches.
Installed panel back to enclose on-demand h20 heater and EMS-PT30X.
Status display clearly visible via top of wood enclosure.
Alex AVI is offline   Reply With Quote
Old 09-16-2018, 10:00 AM   #22
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
ALEX - nice work, very clever solution.
- - Mike
Old 09-23-2018, 07:36 PM   #23
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Thumbs up
I agree as well. Very nice and clean install and all is out of the way and can be removed if replacement is needed...
I like that it is out of the way and one less thing to worry about leaving behind
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 10-05-2020, 11:46 PM   #24
2015 Interstate Ext. Coach
Thousand Oaks , California
Many thanks to Alex AVI for his project to install the surge protector inside. I hired an electrician to do a similar project after leaving my surge protector on the power pole at an RV park this summer. The RV park found the surge protector the next day and mailed it to me but I needed a better solution.
We rewired the exterior plug to a 30 Amp adapter and then wired a second 30 Amp adapter back into the transfer switch. Not as elegant as Alex AVI's installation but just as foolproof. I won't forget to plug it in and it doesn't have to be unplugged when we depart. If it fails I can connect the two adapters for an easy bypass.
Name:	Transfer Switch (2).JPG
ID:	380185   Click image for larger version
Name:	Surge protector installed 2.JPG
Name:	Surge protector installed.JPG
Ryoungca is offline   Reply With Quote
Bumper mounted quick disconnect for portable solar? cdufault Electrical - Systems, Generators, Batteries & Solar 10 03-02-2016 11:18 AM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 04:20 PM
Battery connect or disconnect? AIR-Quarius Batteries, Univolts, Converters & Inverters 11 05-02-2014 10:05 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
