Originally Posted by Pahaska
Believe me, the BMS in my BMW I3 does exactly those things, not only when the HV battery is being charged, but when it is being used in hot or cold conditions. This is true of just about every EV on the road with the exception of the early Nissan Leaf and maybe the smart. Nissan tried to get away with no controls and failed miserably.
I charged in the hot garage yesterday afternoon and the cooling system automatically turned on to cool the HV battery. I normally automatically charge from 11:00 PM to 7:00 AM when the electric rates are the lowest and the temperature low enough that cooling is not needed.
Is that your tow vehicle?
Just kidding, but I have a 2015 i3 and it does a fantastic job of BM. The application in the BMW case is a bit more robust with cooling and heating.
My 250a LifePO4 battery has a BMS but I think it really only throttles the charge current and slows it when you are past 85% SOC. I have watched my input charge amps drop as the SOC nears full. I have a temp sensor as well but it doesn't report much in the way of heat changes and at 14.3V it stops taking anymore charge and the charger output is recorded at zero amps. This is the BMS at work since the charger wants to deliver 55a whenever plugged in.
