The passenger side LED strip lighting under the coach failed to light. During investigation, I found the RF receiver had failed in a on all the time mode and that the strip light was also bad. I purchased a new RF/wall switch kit from ECO-LED and new strip light with adhesive backing was able to repair this functionality. The bonus was that the original transmitter was still functional so I programmed it to operate both the awning and under coach lights and installed the wall switch on inside of the B-Pillar between the passenger door and the slider. This allows the user to turn on or off the awning/under coach lights from inside the RV instead of having to open the passenger door and use the switches on the base of the passenger seat. I have found the location of those light switches to be inconvenient. I can now operate the lights separately from the original location and from inside the RV. Programming instructions can be found on their website.
https://www.rvlighting.ca/en/wireles...switch-remotes
