03-31-2024, 10:12 PM
2021 Interstate 24GL
Drain lines above above generator on AI
Hi random question
While under getting her stir ready to change oil I saw two black drain lines adjacent to /above generator. I didn’t try to trace lines, anyone know where they go to /come from. ( Doesn’t make sense that they dump on top of generator housing.)
2021 AI 24GL 4wd, “maRVel”
06-29-2024, 06:39 PM
Hi.( Bumping )
Still wondering if there an answer out there, thinking the fluid / moisture draining would not be good for generator.
06-30-2024, 12:17 PM
2024 Interstate 19
Fulton
, Maryland
Please post a photo of the lines so we have a better idea what you are talking about and what fluid they might contain. They could just be the propane lines.
What is the size of these lines? What Is their diameter?
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-04-2024, 07:31 AM
1/2 or 5/8 of lines
Sorry for delay got busy but was under van yesterday . There also a similair line that run in behind cabinet area and when water pump is in a AI 24GL and dumps to roadway.
Thank you Boxer, my question should have provided more details.
08-04-2024, 07:38 PM
2024 Interstate 19
Fulton
, Maryland
Those look like low point drains for cold and hot water lines.
Airstream doesn't seem to care where they put them. On the AI19s they are right above the rear leaf spring on passenger side with external valves. Several owners have had them get sheared off by the leaf spring and then lose all their water if pump is on.
See attached photo of their poor design. I moved the valves inside as shown in second photo. I can just reach the internal valves from rear of van. Potential problem solved.
- - Mike
08-05-2024, 07:56 AM
2015 Interstate Ext. Coach
Columbus
, Ohio
Hi.( Bumping )
Since the generator will get wet/dirty from normal driving in the rain etc, I wouldn't worry about the water from the low point drains hurting anything. After all, how many time will you winterize it and flush out those lines?
Adventure before Dementia!
08-05-2024, 09:30 AM
Thanks all for the responses. I agreed generator does live a hard life down there with road scum. I cleaned it when I changed the oil yesterday.
Unlikely they are Lowpoint drains on the 2021 the low point drains are closer to where the gas connection is and they’re made out of that same PEX type hose. This hose appears more automotive. It’s those two black lines and that’s about the middle of the floor of the MH
08-05-2024, 04:47 PM
2015 Interstate Grand Tour
Salem
, New Hampshire
This might help.
08-05-2024, 06:03 PM
Atlanta
, Georgia
I think you are referring to the drains from your tankless hot water heater. One pressure relief drain and one freeze protection drain.
08-06-2024, 09:37 AM
Thank you. I had checked it but didn’t see these two.
I wonder why tankless driving lines are missing off this pdf.
Poster below nailed it.
You nailed it. Thank you, Makes sense now!
08-07-2024, 07:01 AM
2022 Interstate 24GT
Austin
In our GT, you can access the drain valves by removing a cup holder on the curb side just in front of the couch. I would guess your GL is similar. I have used them when I winterized the van by either pumping RV antifreeze or blowing low pressure compressed air through the system.
-Bill
08-07-2024, 11:48 PM
GL drain lines
-Bill
Hi thanks yes the curb side drain lines are under the cup holder by rear lounge
And the road side drains are behind drawer under sink on a GL
The lines in picture, above generator are most likely tankless hot water (Thanks to post above )
