Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 04-14-2021, 01:25 PM   #81
Luckysnuck's Avatar
Liberty Township , Ohio
Wachuko,
So besides the silicone between the ceramic bowl and it's plastic base and at the bottom of the plastic base where it touches the floor, no additional caulking is required on the inner portion of this commode...it's essentially a "pressure fit" there?
Asking because it's literally "Go Time" with this Dometic 320 install...absolutely no pun intended.
Name:	Toilet Connection Opening 4.14.21.jpg
Thanks!
Luckysnuck is offline   Reply With Quote
Old 04-14-2021, 01:33 PM   #82
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
The rubber seal should do its job. So correct. Besides those two areas, there is no need for additional sealant.
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 02-19-2023, 03:17 PM   #83
Rsriley's Avatar
Rio Vista , California
Just put a 321 in my 2018 GT. Would have never tried it if you hadn’t done it, from all the specs you’d never think it would fit but it dose fit just barely! Thanks for all the info and research. Life will be much better now without the flimsy plastic thing that was there.
Rsriley is offline   Reply With Quote
Old 02-19-2023, 04:11 PM   #84
Rsriley's Avatar
Originally Posted by rsriley View Post
just put a 321 in my 2018 gt. Would have never tried it if you hadn’t done it, from all the specs you’d never think it would fit but it dose fit just barely! Thanks for all the info and research. Life will be much better now without the flimsy plastic thing that was there.
Old 02-19-2023, 11:20 PM   #85
wachuko's Avatar
Orlando , Florida
Crown Jewels will be happy!
Safe travels!
Wachuko
WBCCI #26769
Old 09-09-2023, 05:18 PM   #86
2023 Interstate 24GT
Round Rock , Texas
Just wanted to chime in and say I just completed installing a Dometic 321 in a 2023 AI GT and it was a perfect fit!
No fuss at all, took maybe 15 minutes and the only tool needed is an 11mm wrench.
south is offline   Reply With Quote
Old 09-12-2023, 10:56 AM   #87
2021 20' Caravel
2022 Interstate 24GT
Ventura , California
Ive been considering doing the same on our 2022 GT. It looks like the Dometic 311 calls for 10” clearance as opposed to 321’s 11” requirements. Why are you installing the 321 over the 311….are there benefits? Thx
Gerdog is offline   Reply With Quote
Old 09-13-2023, 05:49 AM   #88
Round Rock , Texas
The 321 is larger and much more comfortable IMO. It doesn’t take up much more space since most of the size increase is to the rear (against the wall). The 311 is nice too, but if you’re gonna do the upgrade, might as well go all the way!
Old 09-13-2023, 06:20 AM   #89
Rsriley's Avatar
The 321 is a elongated seat vs 311 round seat. Elongated giving more seat open area men prefer more room.
Dometic 320 in an 1972 Overlander ??? shineybullet Sinks, Showers & Toilets 1 07-16-2015 10:53 PM
Will a Dometic 320 toilet fit a 2015 flying cloud 25 RB? Jukeboxfun Sinks, Showers & Toilets 6 06-26-2015 11:49 AM
Best low profile toilet for above floor tank? drboyd Sinks, Showers & Toilets 0 04-26-2015 10:02 PM
no water to Dometic 320 toilet rbs Sinks, Showers & Toilets 5 10-14-2014 02:45 AM
Thetford Toilet Repair??? Galaxy Low Profile ViewRVs Sinks, Showers & Toilets 11 05-03-2010 03:27 PM
