Old 01-27-2023, 06:50 AM   #1
2015 Interstate Ext. Coach
Sea ranch lakes , Florida
Dash speakers/tweeter
Dash speaker/tweeter is cracking, sounds terrible. I can't find replacement. any help would be appreciated.
Dirkpitt is offline   Reply With Quote
Old 01-27-2023, 10:04 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Are you sure it is the dash speaker/tweeter? I had same issue recently. I first thought it was the tweeter in corner of dash on drivers side. After closer inspection it was the speaker in driver door. I removed cover to see speaker was falling apart. Got a new speaker from local Sprinter dealer. They had it is stock for less than $30. All sounds good now.
I think the speaker in my driver door was most susceptible to damage from opening and closing door after over 10 years of use.
Any of the Mercedes speaker in dash and front doors can be obtained for a Sprinter parts department.
Good luck.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 01-27-2023, 11:23 PM   #3
Hawk-ination's Avatar
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids , Iowa
Crutchfield is a good resource for aftermarket speakers and install advice.
Hawk-ination is offline   Reply With Quote
Old 01-29-2023, 09:25 AM   #4
Luckysnuck's Avatar
Liberty Township , Ohio
Dirkpitt,
After two+ years of tolerating the IMO sub-quality audio emitting from the OEM speaker set-up in my 2018 AIGT EXT, in March of 2021 I replaced both the front door panel speakers and the two rear coach speakers. I DIY'd all the work for it was not that difficult, just a bit tedious and time consuming.
Installed the same speaker at all four locations. I posted a brief write-up on the rear coach speaker install that I've referenced below, along with the product link to the speakers and a few other ancillary items.
When installing the front door panel speakers I unhooked the small tweeter speakers in the upper dash corners. I may have been fine leaving them connected, but since the replacement 2-way speakers I was installing had a tweeter, I did not want to risk any of the new speaker audio competing with the OEM tweeters and it maybe sounding odd. End result; these Rockford-Fosgate speakers sound excellent, good highs, good lows and everything in between. Plus they can easily handle those "oh I wish I were 25 again" moments when you might dial-up Van Halen's Eruption and turn the volume up high!
While I had the front driver and passenger door panels removed for the speaker install, I went ahead and applied Noico 80 mil Sound Deadening Mat. This is a foil clad butyl automotive sound deadener for the purposes of audio noise insulation and dampening. It's a very dense peel and stick product that was easy to work with as the objective was to apply it to all of the inner door panel's metal surfaces. I was extremely happy with the level of road noise reduction in the cabin area of the rig this product provided and now when you slam the door, it’s more of a solid "thud" as opposed to the hollow/tinny sound from the OEM set-up. There are a lot of similar peel & stick noise dampening products available, but this Noico product worked fine for me.
If you choose to tackle replacing the front door panel speakers you'll inevitably break multiple mint green colored door panel clips...buy a bag, you won't be sorry.
Additionally there is a spacer/adapter ring that is required for installation and proper fit of the two 6 1/2" front door panel speakers.
SPEAKERS
Rockford Fosgate T16 Power 6" 2-Way Coaxial Full-Range Speakers
https://smile.amazon.com/gp/product/...e?ie=UTF8&th=1
NOICO 80 MIL NOISE DEADENING MAT
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
DOOR PANEL CLIPS
https://www.clipsandfasteners.com/se...A20879&Submit=
SPEAKER ADAPTERS FOR 6.5” SPEAKERS TO FIT 2007-18 SPRINTER NCV3 CAB DOOR
https://www.ebay.com/itm/141887556531
REAR OEM SPEAKER REPLACEMENT POST
https://www.airforums.com/forums/f24...ml#post2464279
Good Luck!
Luckysnuck is offline   Reply With Quote
Old 01-29-2023, 09:43 AM   #5
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Headphones...
2017 28' Twin Flying Cloud
72 overlander radio speakers emanon25 Electrical - Systems, Generators, Batteries & Solar 6 09-18-2004 12:18 PM
Accessing radio speakers. Cracker General Interior Topics 0 04-05-2004 12:50 PM
rear speakers ALANSD General Motorhome Topics 4 01-25-2003 03:33 PM
Stereo Speakers kntd Audio, Video & TV 4 01-20-2003 06:37 PM
