Old 12-07-2022, 08:55 PM   #1
2011 Interstate Coach
Parker , Colorado
Dash lighting insufficient
Hello: I’m wondering if I’m missing something obvious here. I find the night time dash illumination is way too dim for my 73 year old eyes. I’ve tried to increase the level via the steering wheel controls but I can’t increase it enough to help. It’s a 2011 interstate. Any tips or ideas would be appreciated. Thanks!
Keithco is offline   Reply With Quote
Old 12-07-2022, 09:03 PM   #2
springfield , Missouri
Cool
Is there a twist knob on the light control? Have you tried turning it to the right? Usually, that increases the light on the dashboard.
xpcdoojk is offline   Reply With Quote
Old 12-07-2022, 09:11 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
That is not how it works on a Sprinter.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 12-07-2022, 09:17 PM   #4
Fulton , Maryland
The streeing wheel controls DO NOT control the dash illumination.
The controls are on RH side of instrument cluster as +/- buttons as seen in attached diagrams from the 2010/2011 Sprinter owner's manual.
Hope this helps,
ID:	426018   Click image for larger version
- - Mike
Old 12-08-2022, 06:12 AM   #5
Talking
Is it as hard to find as the little buttons on my SLK Mercedes used to adjust the time? Took me hours the first time to change the clock.
Old 12-08-2022, 09:57 AM   #6
Parker , Colorado
Hope this helps,
Thank you, much appreciated.
Old 12-09-2022, 10:57 PM   #7
2014 Interstate Ext. Coach
Kitty Hawk , North Carolina
My wife commented to me tonite how dim our lights were on our Interstate dash panel, I just walked outside and turned them up. Amazing!
Obxfish is offline   Reply With Quote
Insufficient Furnace Heat frjeff Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-16-2021 11:56 AM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 15 05-19-2020 03:10 PM
Single 15,000 BTU AC insufficient; 18,000 BTU? high vs. low profile fotoman1527 Furnaces, Heaters, Fireplaces & Air Conditioning 15 09-12-2018 08:02 AM
After axle-lift, INsufficient stabilizer travel! Boxite Jacks, Stabilizers, Lifting and Leveling 0 08-27-2016 01:15 PM
ASLY Dash Cluster Lighting Led Replacement is.chowa General Motorhome Topics 6 02-20-2013 08:58 AM
