Nope, they are 2 separate systems.
The Peplink is a Wi-Fi Router that also includes Ethernet Ports and a Cellular Modem. It operates on it’s own and is included with Airstream Connect. You can also purchase the same device directly from a vendor. If you purchase via Airstream Connect, it will be part of Airstreams InControl device control, which will limit what you can do with it. It will also work with the Airstream app. You can request that they release it so you have full control, including using the Peplink app.
Firefly is similar to CZone. Has control screens in the van and also has an add-on Wi-Fi dongle. The Dongle can connect to the Peplink Wifi router or any other WiFi router that is within range so that you can control the Firefly function (Lights, Pump, Heat…) via an app.
