Old 03-29-2019, 11:56 AM   #1
HOUSTON , Texas
Cost to replace house batteries on Interstate GT
I would appreciate any guidance as to cost to expect to replace the current and original batteries in a 2018 Interstate GT with new batteries. A ballpark figure will be sufficient for the batteries and associated labor.
Thank you in advance.
John1048
John1048 is offline   Reply With Quote
Old 03-29-2019, 12:05 PM   #2
Lily&Me's Avatar
Normal , Illinois
If you go to Interstate Batteries, they will replace them with no labor charge.
They could also give you cost estimate for different types of batteries.
We have always used Interstate, and been very happy with them.
Maggie
Find a need and fill it.
Lily&Me is online now   Reply With Quote
Old 04-01-2019, 01:34 PM   #3
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
John1048
They have gone up 50.00 since I got mine... 299.99 each with free shipping.
https://batteryguys.com/collections/...feline-gpl-24t
This is for the house batteries: Lifeline GPL-24T
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 04-02-2019, 04:48 PM   #4
GoingPhishin's Avatar
2017 Interstate Grand Tour Ext
Castle Rock , Colorado
These guys have the original batteries on sale for $259, but I think you have to pay shipping.
https://invertersrus.com/product/lifeline-gpl24t/
Also, to answer OP's original question, I just had mine replaced. I took it to Windish RV in Fountain, Colorado, which is an authorized Airstream service center. They charged me $250 to replace the batteries. I thought this was excessive given it took them less than an hour to replace them. I will likely not go back there in the future.
GoingPhishin is offline   Reply With Quote
Old 04-02-2019, 06:34 PM   #5
wachuko's Avatar
Orlando , Florida
Thumbs up
Free shipping as well from that site you shared. So they are better priced than the link I provided.
Free Shipping on all GPL-24T Lifeline Deep Cycle Batteries!
As to the cost of installing them... these are heavy and not easy to managed under the AI... In my case I had to raise the back as much as I could with the Air Suspension...
So just be careful if you are going to do it and use a motorcycle jack or something with good enough surface that will make it easier to raise into the tray...
Safe travels!
Wachuko
WBCCI #26769
Old 04-07-2019, 02:17 PM   #6
2015 Interstate Ext. Coach
Saint Louis , Missouri
I had the invertor and batteries replaced for total labor of $390. Batteries were $ 298 each. Done this past December. I believe they are the same in 18 and 15 but check on that.
2015 Airstream Interstate Lounge EXT with 9th Passenger Seat
CharlieOscar is offline   Reply With Quote
Old 04-07-2019, 04:26 PM   #7
c21
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
You might consider replacing them with lifeline 6v AGM batteries. They cost slightly more than the 12v Lifelines but you get 37.5% more capacity. You will have to make sure they will fit in the battery racks and you will need to wire them in series instead of parallel. You can obtain the dimensions on the Lifeline website and compare them to what you have now. Swapping batteries is a pretty simple DIY project even changing the wiring configuration. You probably have enough cable and should have a piece left over. I have seen them recently for $330 shipped. The ones you would need are Lifeline GPL-4CT.
c21 is offline   Reply With Quote
Three house batteries in 2011 Interstate BioMedMan Sprinter and B-van Forum 20 02-21-2020 06:28 PM
2007 Interstate T1N rear sofa house battery remove and replace bugsbunny Sprinter and B-van Forum 1 07-15-2016 10:28 AM
If I buy this new 2016 Interstate, might the house batteries already be degraded. RobK Sprinter and B-van Forum 13 03-16-2016 07:11 PM
Replace House Batteries (Magnum Inverter) MILATV Sprinter and B-van Forum 24 11-04-2014 06:11 PM
Interstate house batteries freezing paullovern Sprinter and B-van Forum 29 04-05-2014 09:48 AM
