11-30-2020, 01:42 PM
CaddyDaddy
2019 Interstate Grand Tour Ext
Lanexa
, Virginia
Coffee Maker
Will a 1475 Watt (max) K-Cup coffee maker work in my Airstream GT with the chassis motor running? I know with the 1000W inverter it won’t work with the engine off. My thoughts are ....no matter if the engine is running or not the coffee machine will trip the breaker. I don’t want to start the generator or have to be on shore power to make a cup
of coffee.
So, if I’m correct, I need to look for a coffee maker that draws less than 1000 watts. I prefer a K cup machine. Any recommendations?
11-30-2020, 01:53 PM
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
Or just make real coffee...grind & brew
PREPARE FOR THE BREW SNOBS
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
11-30-2020, 02:58 PM
2018 27' Globetrotter
Mooresville
, North Carolina
We do the same thing as Bob. Better coffee- doesn’t take long to make. We previously used the smallest version of Mr Coffee. It was 500 or 750W but uses so much battery power with the inverter it was not worth it.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
11-30-2020, 03:05 PM
Trilla the Traveling Tube
2018 22' Sport
CHEYENNE
, WY
French presser's here. Boil water in a pan on the stove, pour it in the press and wait 4 mins. Wa-la, you've got great coffee!
As Fate would have it
2018 GMC Sierra 1500
2018 22FB Sport
11-30-2020, 03:15 PM
2017 27' International
Wasilla
, Alaska
Nespresso
One of the smallest Nespresso machines works fine for us even though it claims to need slightly more than the inverter provides. Makes really good espresso. Otherwise, it is cowboy coffee or french press from grounds.
2017 Int'l Serenity 27FB
2020 F250 oil burner
11-30-2020, 04:16 PM
2014 Interstate Coach
Centre County
, Pennsylvania
We found an 1100W K cup machine on Amazon and used it for several years. It worked fine, but it was a battery drain.
This year we replaced it with an Aeropress. Makes great tasting coffee with a lot less mess than a French press.
11-30-2020, 05:59 PM
2019 30' Flying Cloud
Grass Lake
, Michigan
We upgraded our inverter to 2000W along with larger battery bank to run our Keurig. You can’t run a 1475W appliance on a 1000w inverter.
11-30-2020, 06:35 PM
2016 Interstate Lounge Ext
Green Cove Springs
Yep, if you want to make bad coffee with pods while using your stock 1kw inverter, you're gonna have to find a pod machine that draws less than 1kw.
11-30-2020, 07:26 PM
Libertyville
I feed my Vibiemme Super Domobar espresso machine with fresh roasted beans out of a Mazzer grinder every morning at home, so I know what good coffee tastes like. But a quick K-cup brew while cruising 70 mph is hard to beat
This one should work with the stock inverter
CHULUX Single Serve Coffee Maker Brewer for Single Cup Capsule with 12 Ounce Reservoir,Black https://www.amazon.com/dp/B010NMMPH0..._uKzXFbBAAH517
11-30-2020, 07:52 PM
1994 30' Excella
alexandria
, Kentucky
I know you don't want to hear this but I use a stovetop Farberware percolator. Not convenient like the K cup but the flavor is outstanding. A smaller electric percolator only uses 500 watts and these also make great coffee.
Electric percolator:
https://www.amazon.com/dp/B002LVUIK8...=1606787236031
Faberware Yosemite percolator:
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-30-2020, 08:00 PM
2018 16' Sport
Charlotte
, Vermont
Originally Posted by crispyboy
I thought I’d try a fancy Technivorm after using the beauty above for a few years. It didn’t work properly, theres a lot of plastic involved, and the coffee was no better, not to mention it was expensive. Sent it back and i’m happily using my $25 percolator again. Great HOT coffee! And no electricity needed.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
11-30-2020, 08:17 PM
2019 27' Flying Cloud
Kansas City
, Missouri
Now you've opened a can of beans!
I am coffee L-O-V-E-R. After 6 years of Airstreaming I can say that no method is without its pluses and minuses.
Here is what I have personally tried.
Stove top percolator-Plus-doesn't need electricity, makes multiple servings. Minus-takes forever to finish especially in altitude (20 or more minutes), can be a bit too strong or acidic for some.
Manual Pour Over. Plus-faster than percolated. Easy to clean. Easier to adjust how strong it is. Minus-still have to boil the water which can take a long time. Tip over/scald danger.
French Press. Plus-better tasting than manual pour over. Minus-Still have to boil the water. Messy to clean.
Stove Top Moka (pressure) espresso. Plus-fast for a stove top method. Very good pour. Minus-Doesn't make a lot. Some mess to clean. Too strong for some. Have to do it all over agin for that second cup.
Electric Methods (assume generator or shore power)
Nespresso with pods. Plus-very fast at about 40 seconds a cup. Very good taste. Suitable small size for Airstream. Minus-loud--can't make this while partner is asleep. Kind of expensive.
Regular drip machine- Plus-makes a full pot, easy to use. Minus-can be bulky for Airstream use.
K Cup-I have not used in Airstream but assume it's like others I have used in hotels where it isn't especially hot or good coffee in my opinion.
Piggy Bank
11-30-2020, 08:32 PM
2021 28' International
Knoxville
, Tennessee
For years I've searched for the perfect coffee brewing system.
For me it starts with green beans that I roast in my home roasting unit, a Gene Cafe. From there I grind them and use a Yama Siphon pot, the old fashioned way.
However, on the road, I go with convenience and use a mini-Keurig. It's still a good cup of coffee and like most things when we camp, it's a compromise.
11-30-2020, 08:38 PM
2007 27' International CCD FB
San Diego
I've used this k-cup single serving coffee maker for a couple years in the Airstream. Great unit for travel. 800W. And doesn't retain liquid inside once it's done.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
12-01-2020, 01:43 AM
2015 25' Flying Cloud
Washougal
I also use the Vibiemme at home. On the road, I use the Bialetti Moka. Good enough substitute. I pregrind my coffee for the trip to lessen the work. Just have to heat up milk.
12-01-2020, 03:23 AM
Salem
, Oregon
 Hi, we use a stainless steel stove top purcolator in our house and in our trailer. Simple to use and nothing to go wrong.
2005 Safari 25-B "Le Petit Chateau Argent" [ Small Silver Castle ] 2000 Navigator / 2014 F-150 Eco-Boost / Equal-i-zer / P-3 YAMAHA 2400 / AIR #12144
12-01-2020, 07:58 AM
2013 Interstate Coach
Townsend
, Tennessee
This is what I use for my one cup-a-day coffee.
FMCA # 436814
12-01-2020, 09:32 AM
Alamo Heights
Originally Posted by toskeysam
So, it's a larger, less-portable knock-off of an Aeropress?
— David
12-01-2020, 09:39 AM
Zanadude Nebula
, Milky Way
We brew it, we don't fake it.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
Molly Ivins
RLC
Tahawus
12-01-2020, 10:22 AM
2018 22' Sport
CHEYENNE
, WY
I love the good ol' percolator - and yes, you can't find a better flavor than coffee through a percolator!
2018 22FB Sport
