Old 07-03-2019, 11:46 PM   #21
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Originally Posted by Luckysnuck View Post
Wachuko,
I am going to try your suggestion on this "3:00 o'clock setting" on the airflow. It seems as thought I've tried multiple settings around the entire dial with various degrees of success and/or failure. If as you've commented leaving it at this spot has been "good", then that's good enough for me, plus I'm tired of experimenting...I'll share my experience "down the road" as they say...
Thanks!
LUCKYSNUCK - I not sure if the airflow dial affects the freeze-up condition as much as the temp dial and 4-bar fan speed control does, or if it's a weird combo of all of them. I leave mine in the exact opposite 9 o'clock setting all the time in summer. And I leave in 3 o'clock position all the time in winter. And I only use 12 o'clock in rare occassions when I need to de-fog windshield together with the windshield heater switch.
9 o'clock - Directs air through the center and side
air vents
12 o'clock - Directs air to the windshield and the air
vents
3 o'clock - Directs air to the windshield, the air
vents and into the footwell
6 o'clock - Directs air to the air vents and into the
footwell
The "other in-between o'clock" settings generate a mix of the 2 most adjacent main settings.
Alex AVI is offline   Reply With Quote
Old 07-05-2019, 07:00 AM   #22
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Exclamation Recirc ‼️
As a Gulf Coaster.... it is always prudent to keep "recirc" on or closed..... auto and/or motorhome. MB is one of the few mfr's that put a timer on the darned thing......30 minutes I think..... so the occupants get "fresh" air often.
I generally use 80 f as the "recirc" mandate temp
Beemerman is offline   Reply With Quote
New Noise and heater shutting down periodically movin-in Furnaces, Heaters, Fireplaces & Air Conditioning 9 01-13-2015 06:57 PM
Shutting down heater/furnace Ssmookler General Repair Forum 16 11-06-2014 07:19 AM
Arghh!! Generator shutting off 92landyacht Mechanics Corner - Engines, Transmission & More... 15 10-28-2014 08:17 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Door Not Shutting... doglickfarms Doors & Locks 1 04-25-2008 01:02 PM
