Old 04-23-2024, 11:39 AM   #1
2022 Interstate 24GL
Idaho Falls , Idaho
Cellular Wifi pre-wire power feed
The pre-wired cable bundle in the rear upper cabinet of my 2023 AI 24GL is there, but the power cable itself doesn't have any power. Is there a fuse or switch somewhere that would turn that 12v power cable on??
I've searched online and in forums and can't find anything about it.
tjohnson is offline   Reply With Quote
Old 04-23-2024, 01:08 PM   #2
3OnOurWay's Avatar
2021 Interstate 24GL
In our 2021 24GL there’s a keyed switch that is located where your the 120 V fuse panel is.
that’s on the road side rear wheel well underneath the roadside ottoman. God luck because that can key can be the same as your tank heater key or can be different.
2021 AI 24GL 4wd, “maRVel”
3OnOurWay is offline   Reply With Quote
Signal losses using Airstream cellular antenna pre-wire FredWilma Audio, Video & TV 4 10-05-2023 09:42 AM
Cellular Wifi set up on New 2021's with no fridge vent englishw Computers, Internet & Satellite 9 05-21-2022 07:12 AM
Smart App / Wifi / Cellular - Not working mountaindrm 2016 - Current Classic (all lengths) 2 08-17-2020 06:41 AM
My WiFi/ Cellular solution lsbrodsky Electronics & Connectivity 2 04-04-2020 03:16 AM
Wifi and cellular reception inside an Airstream Coalman Full-Timing, Winter Living & Workamping 5 05-01-2018 03:15 AM
