Old 07-03-2019, 08:21 AM   #21
It would be interesting to see where that extra weight is coming from - as much as 440 pounds if we take the differential people weight into consideration, take it off the total difference. That's a lot.
EDIT: Back when I was evaluating this issue closely, I dropped every single item onto a bathroom scale before loading it into the van. Obviously (1) I have gained a few items since I did this and (2) this does not include the weight of stuff that "lives" in the van year-round. I might repeat the exercise again this summer if time allows.
Anyway, this is why I say that a 440 pound differential between vehicles seems to be significant, at least to me, because I don't even take that much cargo in total.
Old 07-03-2019, 09:46 AM   #22
Box Elder (formerly of Center Moriches, NY) , South Dakota
Originally Posted by Boxster1971 View Post
ALEX - you have discovered the dirty little secret of RVs. Most are overweight going down the road. The new Sprinters now come in a 4500 model that has a GVWR of 12,125 lbs.
WHOA! Thank you Boxster1971! I was NOT aware that MB now had a 4500 Sprinter in their line up. In 2013, I fell in love with a 25' Flying Cloud but, the 3500 Sprinter I then owned would have easily gone overweight. The dealer did me a favor telling me that HE would NOT sell me a 25'FC. He offered a 23" which did not interest me. I've since gone to a Freightliner based Super-C diesel puller motorhome. As long as I don't start an anvil collection, I'll never be overweigh!
NY24 is offline   Reply With Quote
Old 07-03-2019, 10:06 AM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Source?
Memory. However, my memory IS faulty. After you asked, I looked it up again in the 2011 Sprinter Operator's Manual, page 284.
The correct maximum roof loading is 660 pounds for a low-roof Sprinter (any length) and a mere 330 pounds for a high-roof Sprinter (any length) for equally-distributed loads. Thank you for asking about the source since it forced me to verify and find my mistake.
Old 07-03-2019, 10:57 AM   #24
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Originally Posted by rowiebowie View Post
Wow, 840 lbs less than Alex. He had more in his tanks plus leveling and air ride but still a big difference.
Maybe it's those 500 switches and outlets he's added. Those little suckers begin to add up after a while.
ROWIEBOWIE - The E&P Leveling system adds 150 lbs. I had 39% more fresh water (10.14 gal = 84.56 lbs.) and 5% more grey (1.35 gal = 11.25 lbs.). So that accounts for approx. 245 lbs. And adding his crew weight of 400 lbs.. (from his figures), so I am still 195 lbs. above WACHUKO's weigh-in.
I do have the 4 yr. old and a 8 mo. old unborn baby in pregnant daughter's tummy. Also, the Lounge has 14 automated shades/motors vs. half that on TB. But all these won't get to 195 lbs.
I think WACHUKO just has skinnier & slimmer crew than me, even though we are shorter. I think crew and I are the ones needing to go on diet
Alex AVI is offline   Reply With Quote
Old 07-03-2019, 11:02 AM   #25
Page 216 in the 2006 manual - same values were given. I've learned something new today.
Old 07-03-2019, 11:40 AM   #26
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by bweybright View Post
Or follow the words of my 25 year old son (who drives an 80,000 concrete mixer truck these days and said" Dude - get your class A like I did or figure out what you want to haul and makes you happy in your life, that is what I did".
From your list of hauling stuff I think you are good.
Getting a Class A does not guarantee you won't be overweight. A close friend, who is an engineer on the US Army MRAP program, bought a Class A. Then he started looking at the axle component specs after he had his rig weighed. The RV manufacturer had installed the wrong axle for the version he bought. The rear axle was overloaded by nearly 1,000 lbs. The RV company replaced the axle after he pointed out their error.
https://en.wikipedia.org/wiki/MRAP
The problem with RVs is that they run fully loaded almost all the time. Even an 80,000 lb. concrete truck is driven under its limit once it dumps its load.
But I agree being only 90 lbs. over the GVMR is not a big issue, and well within the design margin.
- - Mike
Old 07-03-2019, 02:19 PM   #27
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
Alex,
Another data point on AI weights.
We had our 2014 AI weighed by Escapees (they weigh each wheel position). Total weight of our rig with 2 people, our gear, and full fresh water tank (black and grey empty) was 10,200 lbs.
We were far enough below GVWR that we immediately reduced tire pressure all around (after consulting the manufacturerís table of weight vs pressure).
We donít have VB air or hydraulic levelers, and donít carry more than 2 people. Our AI is the non-extended (23 foot) version.
Bottom line...the only way to know for sure is to weigh it!
Lineolated is offline   Reply With Quote
Old 07-03-2019, 04:17 PM   #28
Fulton , Maryland
Source?
The only weight reference I have ever found with respect to the T1N is Airstream's published 100-pound limit for its custom installed roof rack (and that information is only published in certain owners manuals, even though every T1N has such a rack regardless of model year (MY)). We put our solar panels on ours, so we had to evaluate that.
Protagonist was quoting the limit close for a low roof Sprinter, which is 660 lbs.
But the high roof Sprinters, be they T1N or NCV3 have always been 330 lbs.
Attached pages from a 2006 and 2015 Sprinter owners manual. High roof vans have a nasty habit of rolling over, thus lower roof load limit.
Enjoy,
ID:	345313   Click image for larger version
- - Mike
Old 07-03-2019, 04:40 PM   #29
Fulton , Maryland
Originally Posted by Lineolated View Post
Alex,
I've had my 2013 weighed twice.
In 2014 at scales used by my dealer; driver only, full fuel, full fresh water, but propane empty = 9,980 lbs.
In 2018 by RVSEF at FMCA Rally in 2018 after upgrading batteries and Inverter. Two people, full fuel, full water and full propane = 10,875 lbs.
https://rvsafety.com/
- - Mike
Old 07-03-2019, 05:52 PM   #30
Raymond , Iowa
Weighed mine after packing for our 6 week trip to AK. Only missing food in the fridge and wife in the passenger seat. 3760F+6180R=9940
Titus is offline   Reply With Quote
Old 07-03-2019, 06:59 PM   #31
Alex AVI's Avatar
Forgot to post this - I only have 1,397 lbs. to play with. I would imagine a 2019 with 4x4 , VB, E&P, sat dish, 4x batts, extra Tommy Bahama gear would have even less than 1,397 lbs.
2001 Safari Grossly Overweight? Al and Missy Towing, Tow Vehicles & Hitches 38 03-01-2014 09:00 AM
CAT Scale Numbers for 25' Safari greatlakes Hitches, Couplers & Balls 0 03-21-2010 05:17 PM
Cat Scale Etiquette campadk Towing, Tow Vehicles & Hitches 15 11-24-2006 03:46 PM
Are you overweight? troubleskeep Tow Vehicles 6 08-11-2004 03:16 PM
