Old 06-04-2020, 02:30 PM   #1
swilly43's Avatar
escondido , California
Burping water pump - Debris
For the last several uses over 6 months the water pump has been cycling on/off. I have read that this means the water system is losing pressure due to a leak or a faulty diaphragm pump. I search for any leaks and could not locate any. I installed a check valve at the inlet of the pump and this helped but did not eliminate the cycling completely. I investigated rebuild kits but was not please with the purchase price and shipping so I decided to replace the pump. That solved the problem! I disassembled the pump head and found two plastic splinters. One of which was lodged in the check valve of the pump housing. See pictures. Now I have a spare pump! Another repair required due to poor quality control. Not sure where the splinters came from. Lesson learned, take pump apart first before replacingClick image for larger version
swilly43 is offline   Reply With Quote
Old 06-08-2020, 01:31 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Very informative. Thanks.
rowiebowie is offline   Reply With Quote
Burping and Gurgling Mossyrock Waste Systems, Tanks & Totes 0 08-10-2018 07:24 PM
Spring in Air, Debris on New Vulkem eljay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-11-2013 07:04 AM
Suburban furnace burping Blimphauler Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-19-2006 03:00 PM
Burping my Fridge??? airhead Refrigerators 23 11-06-2006 02:56 AM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
