Old 09-22-2018, 09:58 AM   #1
2017 Interstate Grand Tour Ext
Marco Island , Florida
Breaker keeps opening
The 20 amp breaker for the 120 outlet above the counter and for the outside 120 outlet keeps opening but not while using an appliance. It doesn’t pop while we are using anything but as it is idle. With nothing plugged in.
Any ideas as to cause and remedy?
wildwilly. is offline   Reply With Quote
Old 09-22-2018, 10:20 AM   #2
2018 Tommy Bahama Interstate
Washington & Key Largo , Pa. & Fl.
Both of those receptacles are protected by a gfi breaker which is very sensitive to moisture.
I have experienced the same issue after driving in the rain and assume that moisture penetrating the exterior receptacle is causing the breaker to trip.
LewK is offline   Reply With Quote
Old 09-23-2018, 06:04 AM   #3
Brezzin's Avatar
2019 Interstate Lounge Ext
Lakewood Ranch , Florida
I'm having the same issue with the same breaker. I guessing that the GFI breaker is bad. Although covered under warrantee, I'm just gonna go ahead and replace it. It will cost me twice what the thing cost just driving to the dealer
Brezzin is offline   Reply With Quote
Old 09-23-2018, 08:36 AM   #4
LoveToWander's Avatar
Seattle , Washington
Same problem on mine. Replaced with this one from Amazon:
Siemens QF120A Gfci Circuit Breaker, Plug In, Self Testing, 20 Amp, 1-Pole, 120 Volt
Works fine now.
2016 Interstate GT Twin
LoveToWander is offline   Reply With Quote
Old 09-23-2018, 08:58 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Since one of the outlets on the circuit is outdoors ... getting moisture into it is not at all unusual. A spray down with any of the common silicone lube sprays often is the cure. WD40 also has been known to work. Best to power things down before you flood the socket with any sort of spray and leave it powered down while it dries off ....
Depending on what you cook, and in what weather, the kitchen outlet also can get a bit fiddly. Same stuff will "fix" it.
A/C keeps throwing breaker SuzyHomemakr Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-01-2016 06:02 AM
AC keeps tripping breaker - solved 3 Dog Nite Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-17-2011 09:51 AM
breaker keeps trippin' happypill Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:49 AM
AC breaker keeps tripping bmimken Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-11-2006 08:57 AM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
