12-19-2020, 06:53 AM
#21
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Originally Posted by Mr. B
Hi mates! Good thread to learn before replacing that hose!
Did you jack the rear left wheel before unscrewing the square metal box?
We put the business side of the van up on a Lynx leveler block or two to raise that side, chocked it and firmly set the brakes to minimize the risk of movement. I should probably add that we were working on pavement in a level location, which improved safety (no settling, no eagerness to roll). No jacks because I only have the one that comes with the van for changing a flat, and I don't consider that kind of jack safe for under-van work.
That said, it's your van, your risk, and I'm only telling you what we did...not how it should be done. It's a "how I did it," not a "how to do it."
12-19-2020, 08:09 AM
#22
Contributing Member
Austin (Hays County)
I removed, rebuilt, and replaced my macerator by running the roadside tires up on two levels of lego-type blocks. A little tight, but enough room to operate. It was on my level concrete driveway.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
12-19-2020, 01:24 PM
#23
2015 Interstate Ext. Coach
Lake Mary
So, for how many inches you have increased the clearance under metal box before start working under it, about 6 inches? (I am trying to be prepared to make sure it will be enough room for working there)
12-19-2020, 01:30 PM
#24
Contributing Member
I used two interlocking lego-type blocks that added about 2 1/2 inches and worked under there just fine. And, by the way, I am 8 years old and not thin.
John W. Irwin
WBCCI #9632
12-19-2020, 05:47 PM
#25
Lake Mary
Only 2 and half inches... it is really a small addition to the clearance. I would probably be able to increase it to 6 inch. Thank you, the topic is cleared. And btw, how-how old are you? )))
12-19-2020, 07:06 PM
#26
Contributing Member
Should have been 88. Fat fingered it!
John W. Irwin
WBCCI #9632
12-19-2020, 09:01 PM
#27
Lake Mary
That is what I have thought.
You are an old man! )))
And our compliments to your power of DIYing things on the van!
01-15-2021, 07:32 AM
#28
2020 Interstate 19
Pensacola
Shortened hose 2’
Wacked off 2’......makes recoiling much easier.....might take more off soon....‼️
‘20 IS 19’ TB, 2wd
Pensacola,FL
01-15-2021, 07:35 AM
#29
Lake Mary
Yes it does make less stress on all
01-15-2021, 12:57 PM
#30
Green Cove Springs
We may yet do the same. We currently have 20' replacement hose, but the last couple of feet are quite a bear. Of course, I also suspect our reel is failing, so we may also have to fix that...already have the parts kit to rebuild it, just haven't buckled down to git 'er done.
01-16-2021, 06:36 AM
#31
2020 Interstate 19
Pensacola
Poor man’s Lift
This makes under carriage chores MUCH easier.....I use it for Gen oil changes, and recently soundproofed the gen......( I hope it posts correctly!)....
‘20 IS 19’ TB, 2wd
Pensacola,FL
01-16-2021, 09:53 AM
#32
Lake Mary
Good idea for the rear wheels. And how did you soundproof the gen?
01-16-2021, 10:19 AM
#33
2013 Interstate Coach
Waterloo
, Iowa
I bought 25' of replacement hose. Used half for first replacement and saved half for next replacement. Have never found that 12' was too short, and much easier to rewind. Can one manually rewind the hose if/when the rewind motor fails? I assume one can, though not easily.
01-16-2021, 11:32 AM
#34
Green Cove Springs
Yes it is possible to manually rewind the hose if the reel motor fails, but it will be a lengthy and unpleasant experience. Even though our reel has not completely died yet, we know this because when we replaced the hose with a new one it did not want to be wound. The new hose had not been stored with a tight enough coil, so we had to "teach" it to coil as tightly as the reel requires. To do so we had to open the box around the reel from the bottom, and roll it by hand while using a hair dryer to soften the hose as we reeled it in for the first time. Beyond that, we'll see.
01-17-2021, 06:59 AM
#35
2020 Interstate 19
Pensacola
Gen silencing pads...
For Mr. B: I used noise pads made by “Noico”.They are 80 mil silencing pads, I bought the 10 sq ft package. The pads are easily cut in half.......big PITA to slide above and around gen housing....doubled up on sides and top. REALLY improved noise in coach....
‘20 IS 19’ TB, 2wd
Pensacola,FL
01-17-2021, 09:57 AM
#36
Lake Mary
Thanks! Are those pads heatproof, and what type of adhesive did you use if any?
01-17-2021, 11:52 AM
#37
Green Cove Springs
Looks like the pads have their own adhesive layer. "Sounds" like a great idea, as I really hate how noisy our generator is. I even tried an external Cummins muffler that fits on the end of the generator's tailpipe, and while it changed the character of the outside sound to seem less annoying, the DB app on my phone didn't see any difference in noise level. So, quieter would be good.
That said, if the Noico blankets are applied to the generator vs. the vehicle's floor, I would worry a little bit about whether they might cause the generator to overheat while in use. I'm hopeful that it won't do that, and look forward to reports from those brave souls who have applied it, such as Beemerman. Please do share your experience as time goes by.
https://noico.info/
01-17-2021, 07:56 PM
#38
Lake Mary
Yes I agree. It is important if the genset covered with Noico can be overheated especially in hot months when we need to use it for AC.
Beemerman, share your experience on how hot is your generator after a bit of running
01-18-2021, 06:40 AM
#39
2020 Interstate 19
Pensacola
Gen-noico pads
Certainly will share experiences......I could not find any cooling holes or openings that I covered. I will re-visit cooling requirements of the gen.....so far no problems....in 70 degree temps....
‘20 IS 19’ TB, 2wd
Pensacola,FL
01-18-2021, 07:07 AM
#40
Green Cove Springs
Here's hoping it works beautifully!
