Old 01-03-2020, 05:06 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Better drawer storage
The big drawer, right underneath the silverware drawer in my GT leaves much to be desired. The drawer box is only 8" high, while the drawer front is 15" high. That leaves a lot of vertical space free and largely unusable.
I already had a set of full extension slides in the shop. I built a box of 1/2" x 4" hardwood for the sides. I rabbited the inside bottom 5/16" x 1/4" to inset a floor of 1/4" plywood. I got that much done today.
Tomorrow, I'll glue and staple the bottom in place and spray the assembly with clear poly. I'll laminate the face and install the slide parts. I have a matching drawer pull that I removed from the host drawer when I installed a positive latch. I'll install a drop-down arm on the back of the new drawer that will pull the new drawer closed when the host drawer is closed.
By Monday, I'll be ready to install the slides in the AI. That will give me an extra 3 3/4" deep drawer that will hold all of the awkward kitchen tools that don't fit well in the 2 3/4" deep silverware drawer.
Not my original idea. This idea has popped up several places on the web, including these forums.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 01-04-2020, 06:21 AM   #2
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
Please post pictures when you’re done!
Lineolated is offline   Reply With Quote
Old 01-04-2020, 09:50 AM   #3
Lily&Me's Avatar
Normal , Illinois
Everywhere we look in our rigs, there is unused vertical space just waiting for a clever solution.
Looking forward to the pictures.
Maggie
Find a need and fill it.
Old 01-04-2020, 11:49 AM   #4
Contributing Member
Pahaska's Avatar
Ready for install
This morning, I glued and stapled in the plywood bottom, sprayed the whole with clear enamel, laminated the front face, installed the slides, and installed a pull that I had removed from another drawer when I installed a positive locking knob.
The slides are gross overkill, but they were gathering dust in my shop.
Not shown is an arm that goes down behind the main drawer so that when that main drawer closes, it also closes the piggy-back drawer.
I'll install the drawer later today. It should go in easily since I double-checked all of my measurements with the dimensions in the Interstate Parts Manual.
Name:	Piggyback drawer 1.jpg
ID:	358636   Click image for larger version
Name:	Piggyback drawer 2.jpg
John W. Irwin
WBCCI #9632
Old 01-05-2020, 02:50 PM   #5
Contributing Member
Pahaska's Avatar
Some photos.
Here are the photos that were asked for.
I installed the new piggy-back drawer this afternoon. Dimensions were perfect. I slid it in with both parts of the slides and it went in like butter. I based the measurements on the Airstream parts manual.
I pulled out the silverware drawer to get access to mount the new drawer. I had made a wood block the height I wanted the bottom of the outer slide parts to be above the top edge of the host drawer box. I placed this block on the top edge of the host drawer box and used double-sided tape to temporarily stick this measuring block to the sides of the cabinet recess. I then removed the host drawer, placed the slides on top of the measuring block, and screwed the outer slides to the cabinet walls. It worked perfectly! The piggy-back drawer cleared everything quite nicely.
There is just enough friction that the piggy-back drawer doesn't come out when I open the host drawer. I have to pop out the knob or grasp under the face of the new drawer to pull it out. That was what I intended.
I put a patch of sticky Velcro on the back of the host drawer knob. That softly pushes the Piggy-back drawer back when I close the host drawer.
Contents of the drawers are in a mess. Plenty of time to arrange everything later.
Name:	PB Drawer Retracted.jpg
ID:	358688   Click image for larger version
Name:	PB Drawer Half.jpg
Name:	PB Drawer Open.jpg
John W. Irwin
WBCCI #9632
Old 01-05-2020, 03:36 PM   #6
Lily&Me's Avatar
Normal , Illinois
Very nice!
Maggie
Old 01-07-2020, 10:05 AM   #7
Contributing Member
Pahaska's Avatar
Knife Garage
My two long kitchen knives have been a pain to safely store. In the new piggy-back drawer, I built a "garage" for them. The partitions are slotted to the correct depth to allow the knives to store horizontally with the sharp edges well protected.
With the piggy-back drawer in place, there was not enough height for my shorter knives to store vertically. I cut down the plastic knife holder to a V-shape so that it could mount in a corner with the four knives at a 45-degree angle. That takes care of the clearance and still makes the knives accessible. I accidentally left the knives at home, so that photo is just the bare knife holder.
Name:	Knife Garage.jpg
ID:	358861   Click image for larger version
Name:	Slanted Holder.jpg
John W. Irwin
WBCCI #9632
Old 01-07-2020, 06:47 PM   #8
Lineolated's Avatar
These are great ideas! Thanks for sharing. And the drawer turned out very well.
Old 01-23-2020, 07:56 PM   #9
Contributing Member
Pahaska's Avatar
One more piggy-back drawer
I still had an unused set of drawer slides in the shop, plenty of wood, and time on my hands.
I built a 2 1/2"-deep piggy-back drawer for the lowest drawer under the silverware drawer. We will use this drawer to store dishtowels, sponges, and the like. These items formerly lived in the rear overhead cabinet.
I think I'm now satisfied with our galley storage. Three drawers with positive locks replacing the knobs and two piggy-back drawers.
Name:	Lower piggy-back.jpg
John W. Irwin
WBCCI #9632
Old 01-24-2020, 10:34 AM   #10
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Once again, nice work.
Keep it up and you'll have the storage of a "c" in a "b".
rowiebowie is offline   Reply With Quote
Queen bed with lift up storage and drawer plus bedside cabinet Maggiefoss Airstream Classifieds 0 01-05-2017 07:58 PM
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 06:47 AM
Does your under Sofa storage drawer fall out on the floor?? ROBERT CROSS Cabinets, Counter Tops & Furnishings 4 04-11-2016 03:02 PM
Rear storage drawer Geri Exterior Storage Compartments & Access Doors 5 08-02-2003 07:46 AM
Outside rear storage drawer Geri Exterior Storage Compartments & Access Doors 0 07-19-2003 07:57 AM
