Old 06-14-2024, 05:12 PM   #1
2021 Interstate 24GT
Prescott , Arizona
Battery Disconnect Turned Itself Off
I hope someone can help me figure out what happened. 2021 GT 24. The van was not plugged into shore power for about two days (just home from a trip so the batteries were fully charged) so when I left I turned the batter rocker switch at the door off. I got into the van two days later and turned the battery switch by the door on and there was no power. The van started fine. I connected to shore power and the charger indicated good charging voltage but the touch screen would not come on. I waited for a while, still nothing. I went to the back and checked the main power shutoff and it was in the off position. I turned it on and the power came on, touch screen illuminated and everything was fine. I did not turn the main power switch off. My question, is there a situation where it will turn itself off?
Nickel1 is offline   Reply With Quote
House battery goes off when engine is turned off Lily&Me Sprinter and B-van Forum 6 08-06-2018 04:50 PM
2008 Ocean Breeze - plugged in, turned a/c on - turned off - Won’t turn on again samiam8888 Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-04-2018 09:14 AM
Battery Switch Off: Turned On; No power. Did it Discharge? ezra@ezraboo Batteries, Univolts, Converters & Inverters 2 07-24-2016 08:36 AM
Olympian wave 6 turns itself off pauly g Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2008 08:02 AM
Turned off by the new Safaris Raptorrider2001 Our Community 17 09-08-2005 01:33 PM
