Old 07-02-2024, 04:19 PM   #1
Airstream - Other
2022 Interstate 19
Fenton , Michigan
Battery
My start battery always indicates very low voltage, usually 11.8 when off. I would like to replace this one but manual says two house batteries under drivers seat on 2022 19’ airstream sprinter. How do I know which one is bad or is there another battery elsewhere?
Thanks.
Gjhutto is offline   Reply With Quote
Old 07-02-2024, 05:16 PM   #2
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Thanks.
The starting battery is in the driver's floor under the floor mats. It takes a Torx screwdriver (I don't remember the size offhand) to open the compartment.
Brian
ITSNO60 is offline   Reply With Quote
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 10:32 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
