Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-04-2019, 02:45 PM   #1
HOUSTON , Texas
Bath fan blade jammed by power cable
The bath fan blade is jammed by the brown power cable in my 2018 Interstate Grand Tour. The fan has operated flawlessly until now and why the power cable has shifted to get in the way of the fan blade is not readily apparent But by looking upwards from inside the bath this seems to be the problem. The handle that opens and closes the fan lid operates as intended.
My first inclination is the gain access the area above the screen and determine if I can position the cable out of the way.
Is anyone familiar with this problem and can offer advice on how best to resolve.
Your assistance will be greatly appreciated.
John1048
John1048 is offline   Reply With Quote
Old 06-04-2019, 03:21 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The bathroom exhaust fan is a source of problems for me as well. I had the "power cord jamming the fan" problem the FIRST time I had it fixed. The other two times I've had to fix or replace it have been for different reasons, and right now it needs to be replaced yet again!
Old 06-04-2019, 06:55 PM   #3
2007 27' International CCD FB
San Diego , California
Is this a ventline fan you're talking about?
4 screws from the interior will allow you to get at and move the wire. This vid at time 5:00 might help:
https://youtu.be/AJ26sN53Js0?t=302
pteck is offline   Reply With Quote
Old 06-07-2019, 08:23 AM   #4
HOUSTON , Texas
Problem fixed
Solved the jammed fan by going on roof and removing the plastic vent cover (2 screws). There is a foam rubber-like weather strip/gasket that lines the inside circumference of the lid where it seats against the fan body that extends through coach's roof when the handle inside bath is pulled down. The adhesive that attaches this weather strip had failed allowing this weather strip fell downwards and wrapped around the fan blade. Easily removed the old weather strip and new weather strip applied.
John1048
Old 06-07-2019, 08:50 AM   #5
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Good timing.....I just had my bathroom fan jam also.....unfortunately, I also just discovered my macerator is jammed as well. Ahhhhh the RV life.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 06-07-2019, 06:27 PM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Ah yes, RV life and repairs in the middle of a blazing hot Summer.
If you can get to your macerator, there should be a screw slot to assist turning the impeller. If it's just a minor jam, should get you going. Then again, if you hear it running but it's not pumping, check for a kinked hose or be prepared for bad rubber impeller.
rowiebowie is offline   Reply With Quote
Old 06-07-2019, 07:19 PM   #7
toskeysam's Avatar
I always check the rotation at the first of the year. This time it turned freely for just a few degrees, then hit a hard stop....both directions. My guess is I have something solid in an impeller.
FMCA # 436814
Old 06-07-2019, 07:31 PM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
These fans are quite cheaply made. One time I pulled the handle down to close the vent cover and it broke in half. Duct tape to the center and then pull down on the sides. I think my wife finally made me replace the handle. They also leak from insufficient or aged caulk on the exterior. I used it as little as possible rather than have to replace the whole thing because it seemed to have short life.
Gene
Old 06-08-2019, 03:58 AM   #9
Auburn , Georgia
I noticed the foam seal had come loose also. I replaced it with a closed cell foam gasket and used clear silicone to seal it. There is a drain hole in the base that been caulked over with Sika. The picture shows that it had been holding water because of the rusted screws on the lower side. I replaced the screws and sealed them and also cleared the blob of caulk out of the drain hole.
ID:	342742   Click image for larger version
GETRIDAONE is offline   Reply With Quote
Old 06-09-2019, 08:10 AM   #10
rowiebowie's Avatar
2012 Avenue Coach
There is an inner and outer ring under the cap. I think this is a picture of the drain hole you're referring to. It drains the outer ring if water were to splash up under the cap.
Old 06-09-2019, 08:56 AM   #11
Auburn , Georgia
That is the drain hole. The inner ring is shorter than the outer ring, so when the drain hole is covered with caulk and fills up the water will run down inside instead of out the hole.
Old 06-09-2019, 10:36 AM   #12
rowiebowie's Avatar
2012 Avenue Coach
Yep. The design works good so long as properly caulked (but leaving the vent hole open) and a good seal on the underside of the cap. You should be good to go now.
Power Tongue Jack may be jammed thomasjstone Jacks, Stabilizers, Lifting and Leveling 21 07-21-2016 04:10 AM
'82 310 bath exhaust blade source mayco Classic Motorhomes 12 01-27-2015 03:44 PM
I need a bath exhaust fan blade, 1986 airstream alabamabob General Repair Forum 4 03-15-2013 09:21 PM
Vent fan motor/blade Rickman4 Roof Vents, Skylights & Fans 0 01-27-2011 09:44 PM
Bathroom Fan blade jrk247 Roof Vents, Skylights & Fans 1 10-03-2006 04:07 PM
