01-02-2022, 06:04 AM
NORTH MYRTLE BEACH
, South Carolina
Back up camera/rear mirror total blur
Anyone experience this or have a remedy other than replacement? It's been bad from day 1 but I kind of thought it was normal. I use my side mirrors for driving because the camera images are not good. Trying to find answers on YouTube, it seems water may be inside the cameras producing fog. Since mine have been like this from beginning, if replacement only answer, how do you prevent it in future. And where would you go for replacement if you don't have abilities to do yourself?
01-02-2022, 06:41 AM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Most any professional up-fitting shop that handles radio / multimedia upgrades for cars and boats should be able to replace any fogged cameras at a lower cost than a MB dealer, should you wish to go that route.
01-02-2022, 07:22 AM
NORTH MYRTLE BEACH
, South Carolina
01-02-2022, 07:58 AM
2022 20' Caravel
2019 Interstate Lounge Ext
Noblesville
, Indiana
I may have answered this on Facebook...but, you might consider not using your side cameras and put your rear view camera on your display constantly. To do this, you have to remove the center light lense and lighting assembly. You'll find a small circuit board with inputs from each camera and a single output to the display. Thru trial and error, find the rear view camera input, remove it. Remove the display output and connect them together bypassing all the switching to the side cameras when you have your turn signal on. I'd suggest this for somewhat handy techies or someone not afraid of a little disassembly and reassembly of the light.
01-02-2022, 08:03 AM
2017 28' International
Jim Falls
, Wisconsin
I had condensation in my camera this year and had to replace it. It was a bit of a hassle because I had to get the right connectors. Once I had all the right stuff it wasn’t that big of a deal. If you are handy with the right tools it is about an hour job.
1) You will need a heat gun to shrink the connectors.
2) You will need smaller size butt heat connectors.
3) And I had to get some smaller wire to bridge from the small wiring on the camera to the larger wirer on the Airstream.
4) Get some silicone sealer to seal up the holes etc.
5) Obviously wire strippers and crimpers for the butt heat connectors.
A shop would able to do this quite quickly if you can get in.
As to how to prevent condensation that is a real good question. I did put sealant all around the rear camera where there could be a problem of water getting in. Really have no idea what else can be done.
01-02-2022, 12:36 PM
Curtis Wright
2019 Atlas
Saint Cloud
My 2019 Atlas has a problem with the drivers side camera. When I turn on the left side turn signal the view on the screen says no signal. My local dealership in central Florida has been aware of this problem for months. They emailed me to say the factory wants a picture of the problem that shows the no signal message. I guess the factory won't take the dealers word for the issue. It is very frustrating for an owner to deal with something like this. I am still waiting for a reply from the dealer to schedule to take the picture of the problem. The view from the other cameras are fuzzy as well.
01-04-2022, 08:43 AM
NORTH MYRTLE BEACH
, South Carolina
So I went to Mercedes just to find out if it's their problem and what would be involved. They wanted $170 for a diagnostic. I said no, I'm pretty sure I already diagnosed the problem...water in the camera. But I also went in because my center onsole 12 volt not working. The fuse for this is 25!! If I had had a 25, I would have just replaced it myself to see. Again they wanted $170 for a diagnostic...I said no, just check the fuse. So fuse blown, they replaced. Then I said I wanted to talk to the tech to find out why it blew...the only thing I use it for is phone GPS while traveling with a USB plug adapter (since I can't rely on MS Fusion) So he came out and said Apple phones blow them all the time...I'm android. Anyway, he said he thought Mercedes had corrected the problem with the Apple phones, but they recommended increasing fuse to 30 which he did. He also said the camera issue is water, it is not Mercedes installed...it is Airstream and only remedy is to replace. So, that was $40. A bit high for a fuse but at least I got some info, plus I didn't know you could swap one size fuse for another...hope he knew what he was talking about. It is working. I'll check with a local car/truck audio shop to just replace the whole camera system for something better. Does anyone recommend and brands?
01-04-2022, 08:47 AM
NORTH MYRTLE BEACH
, South Carolina
Unfortunately this is a problem when dealing with 2 companies...Mercedes and Airstream. I've had several issues that required a lot of back and forth...just be super persistent! My original fusion was miswired and ended up blowing the speakers...all of them. Airstream replaced fusion and rear speakers. Front speakers were Mercedes so I had to get Mercedes to do it, pay for it, submit receipts to Airstream and wait 3 months for reimbursement.
01-04-2022, 09:13 AM
Green Cove Springs
Yes, we found the same with the camera on the back of our AI. The crummy camera up there in back was an Airstream addition. Even when working properly it couldn't see the rear bumper because it was mounted above the curvature of the back door. It's a terrible, no good, horrible, awful, bad camera. When we had our radio head / speakers, etc. replaced at a professional shop, we had them put a legit MB-style rear camera up there so we can now see the rear bumper while backing up. They left the old one in place so they wouldn't have to stop up any holes, but it's dead now. We also had them install a wide-angle camera on the rear door near the license plate so we have a clear view out the back. That camera is routed to the media screen on our new Pioneer radio, while the upper camera signal still goes to the rear view mirror.
01-05-2022, 08:43 AM
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
This makes me cringe as a large (100) box of fuse assortment is around $10.00.
You really should invest in one and keep it in your Interstate. We’ve probably replace five fuses along the way, especially with the macerator blowing them.
Twice now, we’ve had the alarm sound and have to replace a fuse for it. You don’t want to be out on the road having it go off without the ability to replace it. We leave our fuse assortment in cabinet near the instruments. It takes up little space and is invaluable.
One note, Interstates are not really brand sensitive. Interstate used many components that are common to other RVs and trailers. If you want to save some money and ease, try consulting with an RV dealer/repair shop on your next fix. Or ask on the forum as there are many helpful members who can walk you through suggestions. You’ll probably save yourself a fortune in diagnostic fees averted.
05-02-2022, 04:11 PM
2018 Interstate Lounge Ext
Dix Hills
, New York
I just replaced both cameras from echo master and the rear camera with brake light due to fuzziness and haziness. Spoke to audio and video people and they said then lenses delaminate in time especially in hot weather. So, after 5 years of ownership just changed both today. I bought Echomaster FCT-MB1104 from eBay and replaced just the camera and bought the RVS-916619 From airstream dealer.
05-02-2022, 04:17 PM
Dix Hills
, New York
Definitely need these cameras to work properly in order to drive safely. When calling Mercedes and airstream they all told me lenses were dirty but after cleaning them still the same thing. Really disappointed that they wear out so quickly. I have a 2018 interstate GT and cameras started to get blurry after 3 years. Very unsafe to drive. Not really hard to change but just amazing how bad that nobody knew what to do from airstream and asked if anyone had these problems and they all said this is the 1st they heard of this. From colonial airstream to Jackson OH, no help at all.
05-04-2022, 05:30 PM
Contributing Member
Austin (Hays County)
My rear-view camera has always been blurry while the side cameras have both been sharp.
Oddly enough, when driving in rain, the rear camera is always sharp.
Not dirt. Cleaning it does no good.
It is like the water on the lens corrects the focus.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
05-09-2022, 01:05 PM
2017 Interstate Grand Tour Ext
Houston
I have a 2017 GT. Main rear camera really blurry now. Side cameras still OK.
Whole system is poor quality in my opinion. It's never been really sharp, or useful at night. (Flare from other cars wipes out the image).
Leigh & Bettie
Houston TX
2017 Interstate GT
05-10-2022, 06:19 AM
2017 Interstate Lounge Ext
Mount Jackson
, VA
Just cleaned our 2017 GL for our first road trip of the season. I had pretty good success with using canned air to blow out water from lenses then wiped with isopropyl alcohol. Was very liberal with alcohol on cotton ball then repeated blowing with canned air. Read about this method somewhere and it did help. Moisture is the most likely reason for poor camera quality image.
