We were at WeareAirstream Chandler AZ picking up our 2nd Atlas, a 2023 Atlas E1.
During our walk through for which we were charged a mandatory $979, our guide informed us that he knew nothing about the Volta electric system and the Timberline hydronic heat system. Despite WeAreAirstream’s painstaking prep of our new unit, we found:
1. Firefly touch screen in the galley not working - replacement will be delivered in 3 weeks requiring a trip back for replacement.
2. Bodywork issue silver trim separated from body passenger side
3. As we drove 20 feet we found that the brake lights and turn signals didn’t work due to a problem with the Airstream wiring harness. We had to leave the Atlas at WeareAirstream….we left without our unit
These defects escaped detection at the factory and were missed by the dealer.
WeareAirstream Chandler sent our unit to Mercedes Gilbert who didn’t know how to fix the brake light and turn signal problem. At our insistence, the Atlas was sent to Kate Gurerra at Airstream Phoenix - she found and fixed the problem in 48 hours.
4. Then the air conditioner compressor stopped working and the Timberline heat stopped working - eventually these were all fixed by Kate.
5. After 6 weeks we took the Atlas on a cross country trip and as we neared Texas, the skylight would not securely close and would open when we were driving over 50 mph. Jackson Center, OH was on the way so we stopped in for repair. The Airstream tech said the skylight was incorrectly installed.
6. He also found the external battery compartment door wouldn’t securely close, the kitchen hot and cold pipes were switched, the pantry door lock was broken and wouldn’t open, the bedroom curtain wouldn’t close - rail crooked, the Firefly panel bedroom kept falling out of holder - adjusted & secured, the Timberline needed adjustment of the mixer for hotter water, the couch won’t go up easily, have to pull/assist it, the slide maked scraping sound under couch going in/out as metal frame warped and hits table holder, passenger outside cabinet full of water after driving through rain storm, water pump very noisy, rattling - the tech fixed all these issues at Jackson Center.
7. The shower pan was not correctly installed as it doesn’t drain requiring us to bail water into the drain for 20+ minutes - the tech said this would require a longer repair later as we had to be on our way to Boston.
8. As we got near Boston, the inside dually tire lost pressure - we installed Tireminders on extenders placed by Airstream Phoenix. We brought the Atlas to Mercedes Boston - diagnosis was a faulty tire extender which was replaced with a shorter one.
For the first 18 weeks of ownership, this Atlas was in the shop for repairs for 15 weeks - 80% of the time.
9. March 2024 Atlas was at Airstream Phoenix to fix a leaking toilet seal - wouldn’t hold water into bowl.
10. May 3 2024 trip north to Calgary, noticed inside dually right side alarm low pressure down to 12 psi - unable to inflate. Went to Henderson Nevada Discount Tire - problem was not the tire or the rim but with a loose extender rusted, fell off. That was replaced no charge.
11. July 5 2024 driving through Texas in rain - leak inside slide area, massive leak main cabin entry door - water pouring into van
12. July 8 2024 - 2nd visit to Jackson Center
1. Shower pan fix - removed excess foam that was humping up drain, placed metal bracket around drain hole. Installed new drain pipe. No need to remove shower.
2. Slide mechanism adjusted, with new outer seals.
3. Couch rubbing due to bent frame - fixed.
4. Couch motor replaced, new lubrication
5. Awning above slide was folding in while retracted, causing water to get inside and cause leakage underneath - incorrectly installed - fixed
6. Firefly damage was due to poorly installed air conditioning, condensation tube, causing leakage in the wall - water damage - fixed
7. Water intrusion outer passenger cabinet - new seals and water tested
8. Leak in cabin door seals not well done and new seals added as well as seal door lock
9. Leveling system calibrated
10. Repaired heat vent
11. Volta experts installed Softstart on AC to prevent start up surge
13. Atlas in one year has been seen in 6 Mercedes service centers across the US: Mercedes Benz Gilbert AZ, Mercedes Benz of Phoenix AZ, Mercedes Benz Chesterfield MO, Mercedes Benz of Boston MA, Mercedes Benz of Rochester MN, Mercedes Billings MT for check engine warning, loss of Active Brake Assist function, loss of Active Distance Assist DISTRONIC - unable to use cruise control, gummed up EGR valve, tire extender issues, etc.
This is just a brief list of problems encountered in a “quality” RV with a MSRP of $324,000.
