05-10-2021, 04:53 PM
St George
, Utah
Atlas A/C on 120
If plugged into a 120 V 20 amp circuit, can you run the A/C on an Atlas?
05-10-2021, 07:53 PM
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
If you have the Dometic Penguin II like our Interstates, you are not supposed to run the AC on 20 amp power. Not enough amps for when the compressor kicks on and it’s really hard on it.
05-11-2021, 10:33 AM
2019 Atlas
FOOTHILLS
, AB
If you blow the fuse, then you have your answer.
With a soft start you sure can.
2019 Atlas
05-11-2021, 01:54 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
With a soft start, a big lithium battery pack and a 3Kw hybrid inverter / charger, no problem. With a stock Atlas, I doubt it. That said, if you try it and the breaker at the source for your 20a circuit pops, you will know for sure that it won't. If it doesn't pop, keep a close eye on the entire circuit to see whether any part of it (breaker, extension cord, dogbone, etc.) begin to get hot. Often, an older 20a circuit isn't really capable of running the full 20a all the time, and there's a good chance it will eventually overheat and start melting things.
05-11-2021, 02:21 PM
Pittsburgh
, Pennsylvania
On my 2020 interstate ext the a/c will draw a constant 14 to 15 amps up to 20 amps momentarily when compressor comes on. Sometimes when traveling i do use a 15 amp circuit. I do check the cords etc. Getting hot. Since the surge to 20 amps is less then a second never had a problem.
05-11-2021, 03:37 PM
Alamo Heights
As you can see, the answer is "it depends." Even stock, *IF* you have a dedicated 20A circuit with a suitable 20A outlet & plug (not the usual residential 15A dual-gang) AND you have a short, high-capacity cord it'll probably be OK as long as you shed most of the other house loads in the coach (fridge, battery charging, etc.) Every one of those specs that slips has a cost, though... Long cords, shared circuits, poor connections, other coach loads, etc.
— David
05-11-2021, 07:24 PM
Cedar Rapids
, Iowa
Your AC unit will (probably) run on 20 Amps, but just because it will doesn’t make it good for it. Many posts state that it will burn out the motor eventually, might be sooner, might be later. It’s not getting the voltage it needs to kick the compressor on and starving an electric motor for power is not the best on it. We ran ours (short term) until we knew better and it never blew a breaker. Will only run it on a 30 Amp service now.
05-12-2021, 07:58 PM
Pittsburgh
, Pennsylvania
Concerning Interstates, the A/C is made to run of the generator and that is 20 amp service
05-12-2021, 08:15 PM
Alamo Heights
Does the automatic load-shedding magic work for the shore-power input as well as for the generator?
— David
05-13-2021, 06:24 AM
Curtis Wright
2019 Atlas
Saint Cloud
I'd give it a try. It will just pop the 20 amp breaker if it's trying to draw more current. I don't have a problem running mine. Just make sure that it is the only thing plugged into the circuit.
