Old 08-13-2024, 10:11 PM   #21
Marshall , Virginia
I use a HomeFi router-type device. It can connect with towers from different cell providers even when signal isn't great. Hope this helps.
mar1e is offline   Reply With Quote
Old 08-14-2024, 06:43 AM   #22
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The AS connect Pepwave is a mobile friendly version of that sort of thing. Since it runs straight off 12V, there is no inverter need to power it. The drain on your batteries running the inverter is pretty significant compared to the power a small device consumes.
Any cell based system will have its limits. If you like to go to places off the beaten track, you most certainly will find them. For some folks, going places like that is a "never done that / never would" sort of thing. For others it's "why would you do anything else".
Looking at what *you* want to do is very much part of this. Setting up to do everything everywhere all the time is expensive and takes up a lot of precious space in the RV. You quickly run out of money or out of room ... Might your idea of what to do change over the years? Sure it could. You then re-equip to match your new desires. Less room since you take this out and put that in. Still not cheap, welcome to life
Old 08-16-2024, 03:17 PM   #23
2024 Interstate 24X
Northern , New Jersey
I have a starlink high performance flat dish on top of my Interstate 24X. I can get 200+Mb/sec while underway; it's great. HOWEVER, we always seem to be under a tree at the campsites rendering the Starlink either frustrating or useless. Now I'm considering a Pepwave 5G and would plug the starlink into that. I understand the general concept, but in practice I'm not sure how seamless or effective it is switching to the best network available. I'm going to do my research and then put this in place for next season
mkhllr is offline   Reply With Quote
Old 08-17-2024, 07:21 AM   #24
Half a Rivet Short
2022 Interstate 24X
Hi
The next layer (as you will find) is that cell service isn't available (from any carrier) in a number of places you might be camping. In other places, you have one and only one carrier. If their tower is maxed out, your data service will be poor to none, even with "3 bars" of signal strength. That nice shady campsite down in the deep valley by the creek likely has "cell issues" ..... . I have a *lot* of data on this.
One "interesting" solution is a Starlink Mini (for $30 to $50 a month depending). It's easily portable and if run off a battery can be placed just about anywhere there's a clear view of the sky.
Switching wise, the easy answer is to just leave both the Pepwave and the Starlink on "their own" WiFi. When one goes away, set up your devices to go to the other one.
Old 09-01-2024, 03:41 PM   #25
2022 Atlas
Nottingham , New Hampshire
Update: Coach is out of the shop but unfortunately not 💯 fixed. Ugh. I set up my Peplink router which is working but I didn’t see a connection to the “pre-wire” Athena on the roof. Also, I was trying to connect the MB MBUX to my now coach WiFi router. Wasn’t able to yet. Has anyone done that ?
KAGRIFFIN is offline   Reply With Quote
Old 09-02-2024, 03:49 PM   #26
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
The MBUX system has a built in WiFi router. You would be trying to link two WiFi sources together - I’ve never done that.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 12-02-2024, 11:49 AM   #27
2022 Atlas
Scituate , Mass
Starlink
Hello,
We have the Atlas 2022. I purchase the Starlink last year and very happy with the performance. I stop and start the subscription as needed, which is great. The only time I had an issue was with a campsite with heavy tree cover. As long as you can get a direct sightline to the sky it works well.
As far as the wiring I ran the Starlink cable up from the exterior compartment below the entertainment center and exited the cable out to the small cabinet on the right side of the entertainment cabinet. When departing I disconnect the cable from the Starlink receiver and coil up that cable leaving it in the outer cabinet. The cable is long enough that the receiver can be moved unit finding clear sightline to the sky. We do a lot of camping in the state parks where the reception is very poor and the Starlink comes through.
I would recommend the Starlink system.
Tim
Tim Clinton is offline   Reply With Quote
Old 12-03-2024, 06:46 AM   #28
Half a Rivet Short
2022 Interstate 24X
Originally Posted by Tim Clinton View Post
Hello,
Tim
Hi
The only thing I would change with that setup would be to go to a small / cheap / collapsable tripod to mount the device on ....
I need that little table for my glass of beer
Atlas Owners? or Anyone with Atlas knowledge foleyx4 Airstream Motorhome Forums 15 06-08-2022 02:03 PM
Getting Internet Service into Trailer Dreamnair Electronics & Connectivity 0 05-23-2020 04:14 PM
SpaceX to launch Satellite based internet service amirm Computers, Internet & Satellite 27 04-01-2018 01:26 AM
Internet Service Providers: Which is better? codybear Off Topic Forum 11 12-03-2006 08:36 PM
Internet service Dbraw Forum Admin, News and Member Account Info 1 10-08-2002 07:48 PM
