RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-29-2020, 12:31 PM   #1
Airstream - Other
Lake Zurich , Illinois
Another winterization question
Assuming it will never really be in below freezing except while driving with heat on.. then if left overnight for a day or 2 it would be plugged in with the heat on.. All other times in heated factory...
Can you just completely drain the system and tank, run 5-10 gallons of antifreeze through the system till it comes out of the faucet pink , making sure to run through hot water heater and be good.. Also making sure the grey and black tank have at least a few gallons of Anti and that you also have run it through the discharge and macerator till pink
thx
Sealfit59 is offline   Reply With Quote
Old 10-29-2020, 02:13 PM   #2
richw46's Avatar
Lexington , Kentucky
thx
You really don't want the pink antifreeze in the water tank or water heater. It stays there a long time after it's been drained. I'm not familiar with Interstates. Can you just drain the water heater and put it into bypass? Do you have a way to connect to the water pump so you can pump from the antifreeze jug to the lines? Using an air compressor to blow out the lines would be the best thing.
Maybe an Interstate owner can give you a better answer.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 10-29-2020, 02:21 PM   #3
Traverse City , Michigan
Drain the hot water and bypass it. Then run antl freeze.
Heckler56 is offline   Reply With Quote
Quick winterization question Steamguy Plumbing - Systems & Fixtures 14 11-24-2018 03:00 PM
Winterization Question on a 16' Sport Airabel 2005 and newer - Bambi all models 11 11-07-2017 01:27 PM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 11:06 AM
What to do for winterization? FarHarley General Interior Topics 1 11-25-2004 06:25 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 12:36 PM
