Old 02-12-2019, 05:56 AM   #21
skiphoyt's Avatar
Dataw Island , South Carolina
Thank you...I will check it out. Being a newbie with this I went by the attached response from a Colonial and what the first two smaller Cummins dealers I spoke with.
The generator would have to be looked at and if it needs service it would have to be removed and sent to a cummins authorized dealer. . If you don’t make any head way with the batteries I would advise bringing it in to be looked at.
Hope all is well with you and have a great day.
Thank You,
JTL
Service Advisor
Colonial Airstream & RV
800-265-9019
www.colonialrv.com
skiphoyt is offline   Reply With Quote
Old 02-12-2019, 06:33 AM   #22
Lily&Me's Avatar
Normal , Illinois
Well, it still makes no sense, as our generators don’t generally need to be removed and sent off to be serviced.
I would read your warranty information thoroughly, and perhaps call Jackson Center and the service department there to see what they have to say, should you not find a simple solution to your leak.
Removing it and sending it off seems unwieldy to the point of maybe being a deterrent to having it serviced under warranty.
If that is some agreement between Airstream and Cummins, it should be reduced to writing somewhere in your warranty information.
Plus, these are big and heavy and shipping them back and forth seems to carry its own risk of damage.
Maggie
Old 02-12-2019, 08:41 AM   #23
Sag Harbor , New York
Originally Posted by skiphoyt View Post
. . . I went by the attached response from a Colonial . . .
Sorry I forget, was Patrick Botticelli your sales person? I would call him right now and light a fire under him, under Colonial, and under Airstream.
Did I read someplace that you have a 2020 AI on order?
Your baptism by fire on this new model has gone on long enough IMO.
Time to get the band playing your tune!
Good luck,
Peter
Old 02-12-2019, 08:46 AM   #24
PSchw's Avatar
2005 39' Skydeck 390 SD
Hillsboro , Texas
I personally would not worry about the generator too much. It has a low oil sensor which will shut to generator down in a low oil scenario. It happens several times to mine after several minutes running I added a little and it worked fine. This was after it was serviced at Jackson center.
Peter
PSchw is offline   Reply With Quote
Old 02-17-2019, 10:49 AM   #25
2012 Interstate Coach
norman , Oklahoma
I would have some concern about the generator having been run low on oil. One option would be to refill and then next time it's do for an oil change, take a sample of the used oil and send it in for an oil analysis to check for any excess metals that would indicate bearing damage. I've used Blackstone for oil analysis before with good results.
russ240 is offline   Reply With Quote
Another Challenge. overlander63 Off Topic Forum 239 05-07-2022 07:11 PM
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 04:48 PM
Deck the Halls - challenge! Janet H Our Community 3 12-20-2003 12:02 PM
An ID challenge afrangos Airstream Motorhome Forums 13 07-14-2003 05:40 AM
take the VIN# challenge femuse Our Community 1 03-17-2003 01:18 PM
