Originally Posted by troypegg
We have a 2021 Airstream Atlas Tommy Bahama on in our first
A few days ago the travel warning begins blinking alerting us that the awning is extended which upon further inspection is false.
TROYPEGG - Just to follow up on my 1st response - first I was not completely paying attention and did not realize you have an Atlas. I was strictly addressing the actual awning electricals and the said microswitch since you were specifically asking about that. The awning electricals itself is identical whether it's in an Atlas or an Interstate (mine). But now I realize you were talking about the RED LED Travel Warning indicator under the dash. Per AS any one of 5 issues (or combination) can trigger that RED LED such as an open compartment or extended component which will make driving unsafe. They are Exterior Compartment, Awning, Skylight, Stabilizer Jacks or Door Step.
Firefly display will/should be confirmed that it is indeed the awning and not any of the other 4. Has that been confirmed? Even if it has, have you cycled (out, then back in) all the other 4 possibilities? The cycling of all 5 is per AS recommendations. If all confirmed, then please disregard all the above.
