Old 07-19-2019, 09:51 PM   #21
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Originally Posted by bugsbunny View Post
Hi Wachuko,
What is the height of your grill when collapsed? I am looking for a new one because the Weber will not fit in my Interstate without trouble...
Thanks!
I will try to take photos this weekend and confirm... but it is about 6.5"...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-21-2019, 02:04 PM   #22
Napa , California
Most regular gas grills -even the tail gate type require a higher pressure than the gas from the trailer. Hence the "Airstream WeberQ" which is already modified or creating your own connection to allow for the lower pressure gas to work with whatever you have (and to work back on the regular little bottles you have to unmodify).
We looked into that, but since my husband prefers to cook away from the trailer and to grill on the Weber Q at home as well, decided against it.
Atwebs is offline   Reply With Quote
Old 07-21-2019, 06:28 PM   #23
2018 27' Globetrotter
Mooresville , North Carolina
I picked up the same Airstream Weber grill at Alumapalooza at Jackson Center. I have had a Weber Q1000 for around 15 years and it was starting to show a few problems. I was considering removing the regulator to have it work with the Airstream propane quick connect. Rather that spend money refurbishing my old Weber Q I just purchased the newer Airstream model.
I also have an Outland Firebowl that runs on propane. I was getting tired of hauling the propane tanks in the bed of my truck (20lb for the firepit and 5lb for the grill). Since my new Weber uses the quick connect on the Airstream, I went to a local propane shop and had them remove the regulator from the Outland Firebowl and add the same quick connect that is on the Airstream Weber grill. We followed instructions from Outland on how to do this, (you are basically removing the regulator just like you would on a non-Airstream Weber Grill). I then purchased a 17’ propane hose, (that has the same fittings as the 10’ Weber grill hose).
Now, I should be able to run my Weber grill and my Outland Firebowl from the Airstream propane tanks. I will use the 17’ for the firebowl and 10’ for the Weber grill.
Lastly, there may be occasions where I would like to use my Firebowl or Weber grill at home off of regular propane tank. I had the same company make me a 10’ hose with a regulator to screw into my propane tanks at home and a quick connect fitting that will attach to the Firebowl and Weber grill, see the picture attached. It has been so hot here lately I haven’t tried them both out yet but I can’t see why this won’t work and allow me to you these on the road and at home. I will test later this week when the cold front passes through.
Name:	Propane Connecter w-regulator.jpg
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 07-21-2019, 07:32 PM   #24
turk123's Avatar
2019 30' Classic
Canfield , Ohio
For those who want to do this on their own or want to convert their own weber, there is a kit to do so on Amazon. $38. 12 ft. hose. I bought this and the color I wanted (Q1200 / blue) and saved some money and free shipping. It's just a couple of bolts to take off the regulator and then just add the quick connect. This will fit quite a few Weber models.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 07-21-2019, 07:37 PM   #25
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I posted something on another thread, I dont like have the grill at the front of the trailer so i use flameking refillable 1lb tanks.
https://www.homedepot.com/p/Flame-Ki...LBKT/305539519
Available from amazon and other places too. I keep 2 in the airstream which is plenty for a couple of trips.
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-22-2019, 05:50 AM   #26
Hans627's Avatar
2009 25' FB International
Hanover , Pennsylvania
Hi Jim,
Just curious where you bought your 17' propane hose?
I just bought an Airstream grill while attending the Internationally Rally in Doswell. But I would like more hose to move the grill farther away from the AS.
Old 07-22-2019, 05:36 PM   #27
Originally Posted by Hans627 View Post
Hi Jim,
Hi Bob,
Nice to hear from you again! Still loving the extra towel hanger you sent me last year for our Globetrotter. I got the hose on Amazon, see the picture below for the item description as I couldn't figure out how to copy the link here. Also, it was 20' instead of 17'.
In full disclosure, I contacted Weber to try and get another 10' hose or longer to extend the one supplied with the grill. Weber told me they only recommend the hose that came with the grill and if I use a longer hose it could possibly void any warranty. Personally, I don't see how this hose would not work as it has the same connections, etc.
I bought this hose for the propane firepit so it would be further away from the RV. I will probably also try it with the grill some as I've read others using a longer hose with their converted non-Airstream Weber's. However, I did want to supply you with all the information I gathered in doing this little project.
Hope to see you on the road sometime.
Name:	20 foot propane hose.jpg
"Roadrunner"
Old 07-23-2019, 05:28 PM   #28
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
I just got this stainless version but 12 feet long, for connection to the low pressure propane port with quick connect.... arrived yesterday, will test soon!
https://amzn.to/2YcdeMm
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 07-23-2019, 06:12 PM   #29
FishByFly's Avatar
2017 25' Flying Cloud
Fort Worth , Texas
Is there a problem connecting two hoses together for more distance? I bought two 12’ hoses with quick connect ends. Seems to work by just linking them together for those times we want to move the grill further away.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - “Fly Fish Inn
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 07-23-2019, 09:10 PM   #30
UncleBad's Avatar
Marana , Arizona
Should work just fine....
Old 07-23-2019, 09:33 PM   #31
2007 22' International CCD
The only possible issue would be pressure drop due to high flow rate.
rmkrum is online now   Reply With Quote
Old 07-24-2019, 06:31 AM   #32
Mollysdad's Avatar
I like the braided stainless, but isn't that an extension instead of a grill hose?
Old 07-24-2019, 07:26 AM   #33
UncleBad's Avatar
Marana , Arizona
Correct.
It connects to the Coleman Roadtrip grill using this:
https://amzn.to/2M90QtX
That way the hose is generic and I can use it for other things. Keep your hoses generic with quick connects and adapt grills and generators to use the quick connects. You have a lot of flexibility that way.
Old 07-24-2019, 07:52 AM   #34
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
For those using a low-pressure converted Weber (and probably other grills as well), Torjik sells a little QC hose with a regulator that allows you to also use the green bottles if you want. So you can run off your airstream or remotely on a green bottle by selecting the appropriate hose.
I run off the airstream but have a green bottle in my outdoor kitchen kit as an alternative option.
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Old 03-01-2020, 10:23 PM   #35
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Hi all -
Is this the Q1100 (or similar) that can be relatively easily converted to low pressure propane (to tap directly off the outlet at the front of the trailer)?
It looks like it, but I'm not that familiar with grills and the pictures are just 'ok'.
Name:	Screen Shot 2020-03-01 at 9.18.10 PM.png
ID:	362368   Click image for larger version
Name:	Screen Shot 2020-03-01 at 9.22.41 PM.png
doughpat is offline   Reply With Quote
Old 05-27-2020, 06:09 AM   #36
Pickles's Avatar
2007 19' Bambi
2020 27' Globetrotter
Chicago , Illinois
Having trouble heating up the Airstream Grill. Doesn't get hotter than 200. Need suggestions to trouble shoot. The first thing we did was to use the other full propane tank.
Didn't help.
Pickles is offline   Reply With Quote
Old 05-27-2020, 06:26 AM   #37
gator.bigfoot's Avatar
KW , Ontario
Originally Posted by doughpat View Post
Hi all -
Yes. They are great grills. But why convert them. I use a 10lb tank with it and I hook up both my Coleman stove and the BBQ at the same time. Lasts 3 to 4 weeks and I can move it where I want. I have the stand for the BBQ and a portable table for the 2 burner stove. A lot more flexible than the fixed outlet. I store the tank in the back compartment under the bed. Just need to turn sideways to get it through the door, then it can stand upright. Same compartment holds the BBQ. Just need to remove the lid.
gator.bigfoot is offline   Reply With Quote
Old 05-27-2020, 08:14 AM   #38
Originally Posted by gator.bigfoot View Post
Yes. They are great grills. But why convert them. ....
Because this is a van subforum. Van owners have immense difficulty traveling with anything other than their chassis-installed propane tanks. We have no integrated exterior storage and no TV.
Speaking of which, travel circumstances have changed with the pandemic, and now I, too, am in the market for a van-compatible propane grill to augment my charcoal and wood cooking options.
As discussed on multiple threads, T1N Interstate owners cannot Y their onboard propane tanks because the rear leaf spring is in the way of the manifold. We need to carry separate tank(s) if we are going to grill using gas.
So, I'm now shopping for a micro-grill and micro-tank(s) to go with it.
Up until now, I've grilled using wood harvested from my own acreage. But I can't start wood fires on my property when the wind comes from the north - it's not safe. This wasn't a problem prior to now - if we had a north-wind day I would just do something else that day. But now we have ongoing pandemic restrictions and closures, and I need to increase my on-property options.
I know that this thread is titled "Weber", but if anyone else has tiny grill suggestions, please pipe up. Thanks.
Old 05-27-2020, 10:33 AM   #39
Reverting to the Wachuko and Bugs sub-discussion...
I've reviewed the tiny, tiny, tiny propane grill options, and at this point, I do not see a superior alternative to the Magma little kettle.
HOWEVER, oh my gosh, its shore stand *sucks*! Clearly they anticipated near-100% boat usage where it would be attached, and the shore stand was a total afterthought. I want a decent shore stand that folds up - not that abomination with three legs sticking out in all directions. There is no picnic table where I'll be taking it. And I don't attach grills to the side or rear of my van. The cooking smoke will just permeate the van if that is done. It needs to be situated away from the van.
Old 05-27-2020, 05:43 PM   #40
The original small Magma is currently on sale for $150 at West Marine.
I picked one up and will post back when we have stand-related modifications designed and built to maximize the efficiency of carrying it in the Interstate.
The Perfect BBQ Grill and Awning for my New Airstream sthrngary 2016 - Current Flying Cloud 41 04-14-2019 07:49 AM
Rare Tito’s Custom Airstream Grill di-dc Airstream Classifieds 0 09-12-2018 08:47 AM
Rare Tito's Custom Airstream Grill AirstrmQueen Airstream Classifieds 1 02-16-2017 02:00 PM
rd webber - tow combo? R. D. Webber Member Introductions 8 10-27-2007 08:28 PM
