06-06-2020, 02:50 PM
2011 Interstate Coach
Houston
Airstream vs Advanced RV - need input
I owned a Airstream Interstate for a few years and loved it. However there are a few modifications I would like to have now that I am looking to get back into the market.
1.) 4 wheel drive - Airstream was too low to the ground.
2.) no propane - Diesel heat and a set up with Lithium Batteries to run the AC. Is that possible?
3.) separate shower from the toilet so ok with removing the 2nd row seats.
So are there options for modifying the Airstream Interstate?
I could go to Advanced RV but it takes a year to get one.
Any advice or thoughts would be appreciated.
Brent
06-06-2020, 03:38 PM
League City
Airstream now offers 4x4 and running the A/C off batteries is doable. We do it in our modified 2007.
If you can’t DIY the mods and can afford Advances RV, that’s your answer.
Even if you can DIY the mods, it will take time and Advanced RV could still be faster.
If you can’t DIY and/or don’t want to spend the premium for Advanced RV, guys like Lewster can do the lithium conversion and inverter upgrade. Not sure who I would trust with the cabinetry and plumbing for the shower buy Airstream will sell the laminates or give you the part numbers so matching the woodwork is doable. Dumping the propane and adding a diesel heater is pretty easy and can probably be done by most competent RV shops. The nice part is that the NCV chassis has an aux fuel pickup on the tank if I remember correctly. You’ll probably want to convert the cooktop to induction as well.
06-06-2020, 03:44 PM
Grace the Airstream
2020 27' Globetrotter
Powhatan
, Virginia
What type of system did you put together to run the AC off the batteries?
I was thinking of upgrading my solar and battery capacity to do that but interested in your experience.
06-06-2020, 03:56 PM
League City
You can read about it here: https://www.airforums.com/forums/f24...es-151809.html
It may be easier to start at the end of that thread and work backwards so you don’t start with our mistakes and misconceptions.
06-06-2020, 04:07 PM
2024 Interstate 19
Fulton
, Maryland
I’ve been looking closely at Advanced RV for years as a replacement for my 2013 Interstate. I’ve even attended two of their festivals to get a close look at their operations. But in the end I don’t think I want to pay that much for a replacement. Their conversions are absolutely top quality. Buying a B-van form ARV is like building a custom home with an architect. You get to have it built exactly the way you want it. But that custom approach comes a a price. You can plan on spending $300,000 or more for a fully custom Sprinter 4x4 build.
If you have the funds and don’t mind spending that much then ARV is your top choice. A highly modified Interstate will never come close to an ARV build.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
06-06-2020, 04:48 PM
2019 30' Classic
New Milford
, Pennsylvania
I went to Advanced RV factory to have one of their quiet a/c unit installed on a previous rv. Met Mike Neundorfoer, the owner, who showed me around the factory and his own unit. If I was looking for a "B" and had the money, I wouldn't even look at another brand. Top of the line battery/inverter tech, custom work, you pick the interior, and workmanship is great. All wiring is loomed, clamped, and secured, not stuffed in a big ball under a cabinet. Still worth looking into.
06-06-2020, 07:37 PM
2017 Interstate Grand Tour Ext
Western
, Tennessee
Brent
Arriva made by Coach House (near Tampa, FL) has a B class with separate shower and toilet.
https://www.coachhouserv.com/
06-07-2020, 04:37 AM
League City
My husband LB_3 replied by linking a very cumbersome thread instead of our final system write-ups. You can find three out of the four of those write-ups here. I never did get around to finishing the DC system description.
Anyway, to the OP, I'm +1 on ARV. If you can afford it, it's the way to go - there's no question.
The second-best alternative will always be passionate DIY, but not everybody is interested in that alternative. It will eat your life if you decide to go that way.
06-07-2020, 01:55 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
if you go Lithium(Li)/solar you can get about 4+- hours of use with a 13,500 but A/C. Look at the lithium battery bank dimensions first to see if you have space for them out of the weather. If you go diesel are you going to cook with it? An electric stove would eat up your Lis in a hurry.
guskmg
06-08-2020, 06:20 AM
2013 Interstate Coach
Waterloo
, Iowa
I think one should have owned at least one Class B before buying from Advanced RV. IMO that's the only way that one would know what features/designs/layout does and does not work for them. It is especially important to know what lifestyle you plan to have with your RV. We have 200W of solar and the standard batteries and Magnum invertor and that works well for us - but we seldom are sitting in one place for more than 1 night. We are not ones to go and sit by the lakeshore (or whatever) and do nothing. We like activities (of course that may change as we age!).
It is a bit of a nuisance to have to fire up the generator to run the microwave for a few minutes. But not enough of a nuisance that its worth the time and $ to put in a larger invertor. And if we were to go with a larger invertor to run the microwave for a few minutes then we might need more battery capacity, then more solar, then …
In short, opinions of others may be right for them, or not, but may not fit your planned situation.
06-08-2020, 06:34 AM
League City
Originally Posted by Titus
I think one should have owned at least one Class B before buying from Advanced RV. IMO that's the only way that one would know what features/designs/layout does and does not work for them. ...
Well, I agree with you generally, but in this specific case, the OP already has met that criterion. He opened this thread with, "I owned a Airstream Interstate for a few years and loved it. However there are a few modifications I would like..."
06-08-2020, 07:02 AM
Houston
Thanks for the input. I think I will go visit Advanced. We don't do a lot of cooking inside. When we had the Airstream Interstate I did more grilling outside.
06-09-2020, 11:50 AM
League City
I don’t like having wires with hundreds of amps going through them so you may wish to consider a 24 volt system.
06-09-2020, 12:22 PM
2015 Interstate Ext. Coach
Columbus
, Ohio
We've looked at several of ARV used models and noticed that their cooktops are portable and stored in a cabinet drawer.
Will you cook outside on their induction cooktop(s) or take propane along to use to grill outside?
Adventure before Dementia!
06-09-2020, 01:06 PM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Originally Posted by TN Princess
Coach House is definitely worth a look. Relatively small, family owned business. They don't do one-off customs like Advanced RV but it's my understanding they will tweak a few things here and there if possible. We've spoken to the owner and sales team several times at the Florida RV SuperShow. If we hadn't found the Interstate that was to our liking we may very well be driving a Couch House. As TN Princess mentioned... Coach House has one of the few dry baths in the Class B market.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
10-21-2020, 07:19 AM
Traverse City
, Michigan
So a week ago I camped in line for 2.5 days to get into the racetrack and another Sprinter shows up. I had to go over and introduce myself and talk vans. Edward was happy to take me through his Advanced RV camper. As others have mentioned totally custom. Fit and finish exceptional. All the details into every aspect of grumbling seen here has been addressed. Diesel heater, lithium (each cell monitored and replaceable), runs quiet ac for 14 hrs, no generator, macerated easily accessible and hose coiled in bin - not on a hose reel, on and on.
But the price tag on this mind numbing. Kudos to Edward and his wife having owned it 3 years, used it for 378 days, only paid for camp sites 10 days.
10-21-2020, 07:48 AM
League City
Originally Posted by Heckler56
... Edward was happy to take me through his Advanced RV camper. .... Fit and finish exceptional. All the details into every aspect of grumbling seen here has been addressed. ..... But the price tag on this mind numbing. ....
There is a gaping market hole, a no-man's land between mass-produced Airstreams and custom-built ARVs.
Every once in a while, my husband and I get a wild hair and speculate about how we could fill it. ARV is that expensive mainly because everything that rolls off their assembly line is a one-off. We could produce vans that are near-ARV quality but in a small number of standardized formats that lend themselves to production economies of scale, thereby charging $150K for the same quality that fetches $300K at ARV.
The prospect has become more attractive with the pandemic and the increase in interest in B van ownership. But it's a difficult, risky way to make a living, when an abundance of easier ways exist to realize the same net income. And that, my friends, is why the market hole persists.
10-21-2020, 11:28 AM
Traverse City
, Michigan
I say stick to your day jobs and keep us educated on improvements we can make. Your’s and LB’s insight have educated the masses here. From my perspective, the generations behind the baby boomers are not going to have anywhere near the disposable income to afford these in the future.
10-21-2020, 12:35 PM
2014 19' International
2014 Interstate Ext. Coach
Cedar Rapids
, Iowa
Leisure Travel vans fits a lot of your check list too. Don’t come at me...
10-21-2020, 01:16 PM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
I sure hope you are wrong... I am planning on living off my kids
Joking, joking!!
Oh... and I am part of next generation after the Baby boomers... looks like I fall into the GenX
