Old 04-14-2025, 06:09 AM   #1
2025 Atlas
Palm Harbor , Florida
Airstream Atlas Entry Door
New 2025 Airstream Atlas entry door not flush to coach body, is this normal, seems like a possible common issue? First night out in rain had water intrusion.Click image for larger version
MNorrisTampa is offline   Reply With Quote
Old 04-18-2025, 06:31 PM   #2
Airstream - Other
2024 Atlas
Ventura , California
Would be easier to tell if your picture was oriented correctly. I’m not the best with that edit her but I recall that I read if you crop the picture slightly it will orient correctly. With that said that doesnt look normal, ours is flush with the body. I would take it to the dealer since it is still under warranty.
Gerdog is offline   Reply With Quote
Old 04-18-2025, 07:02 PM   #3
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
That is not normal and there should not be water intrusion in the rain.
Door needs to be adjusted.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 04-20-2025, 10:19 AM   #4
2007 27' Classic FB
2001 25' Excella
2001 30' Classic S/O
2022 Atlas
Western slope , Colorado
Originally Posted by MNorrisTampa View Post
New 2025 Airstream Atlas entry door not flush to coach body, is this normal, seems like a possible common issue? First night out in rain had water intrusion.Attachment 452304
I had the same issue and here is the fix....
The striker bolt was not aligned prperly from the factory. I spent several hours trying t adjust the striker bolt inward to where the door would close flush. That did not seem to work and made me look more closely at what was going on. Apparently the latch on the door has two stages of locking. My lock was only in the first stage when the striker bolt was adjusted at the factory location and when I adjusted it more in, in being towards the inside of the Atlas. The fix was not intuitive as I had to move the striker bolt OUT just a little from the original location...Take a socket with a ratchet and unscrew the striker bolt to loosen, just a little, don't unscrew it all the way or the backing plate will drop and you'll have a time trying to get it back aligned....ask how I know.
Once you have the striker bolt loosened move it outward, just a little and then tighten it. don't move it up or down, just a little outward. Try the door to see if the latch on the door engages to both latch settings, and the door is flush. If not repeat the loosening and adjusting out. This all worked for me.
This was not intuitive as I did not know the latch engages twice, I think it has to do with safety standards
Also, on my door there was no weatherstrip on the underside of the door. a trip to Lowes or Home Depot and a few dollars fixed that with identical weather stripping.
Let us know how this works.
Best
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Atlas Owners? or Anyone with Atlas knowledge foleyx4 Airstream Motorhome Forums 18 04-13-2025 06:17 AM
Replacement Keys for Entry Door/Water Input door? Marlin4622 General Repair Forum 4 09-22-2018 07:11 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
