Originally Posted by Gintory
We have a 2021 camper on 2019 chassis. It has 4 AGM batteries which are now starting to discharge quickly. Wanted to upgrade to lithy's bur Airstream told me today cannot be done, charging system change for coach batteries would not be compatible with chassis battery, since they do interact.
Hi
With a compressor fridge, battery capacity is an issue. The other things is that it takes a *long* time to fully charge lead acid batteries ( AGM or flooded ). A lot of folks stop the charging process based on voltage readings. That likely only gets you to about half of the usable capacity you should have. ( = you run from 50% charged up to 100% ).
Switching to lithium is more than just dropping in new batteries. As noted, the charging system needs to get changed around. You need a lithium compatible inverter / charger ( which you likely have). It needs the right settings for the new batteries ( so reprogramming is involved). You also need a DC / DC converter between the alternator and the new batteries. Solar also should be reprogramed.
Is all that stuff impossible to do? Certainly not. A dealer should be able to quote you what it will run. Can you do it DIY and save a bit? Sure, but there is some work involved and some tools to buy.
Fun !!
