Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 04-19-2021, 04:10 PM   #1
2021 25' Flying Cloud
2014 Interstate Ext. Coach
Angier , North Carolina
Adding DC circuits on my Interstate
I am adding a couple of new circuits to my 2014 Interstate for charging my phones and iPad and other 12 equipment. I'm confused by the DC side of the load center as there are no individual negatives from the various existing circuits attached to the negative bar. For my new circuits, do I bring my negative sides directly to the vertical bus bar where the large white jumper is attached?
StephensNC is offline   Reply With Quote
Old 04-20-2021, 06:27 AM   #2
Wapakoneta , OH
You should not have to add any grounding at the distribution panel. The distribution panel has only 1 DC ground that all the circuits pass through. As far as adding the circuits are concerned, this is what I would do to determine if you can add them:
1. Throw on all your DC load.
2. Use an amp meter to determine how much current is passing through the ground wire with all your DC loads on.
3. Run the new circuits you want to run on the floor and plug in the devices you want to be able to charge. As far as grounding is concerned, try tapping into nearby DC grounds. Make sure that the ratings of ground wires you're tapping into can handle the additional amperage (if you're able to add the circuits permanently, I would break them up among your remaining circuits in the distribution panel. Laptops can use as much as 10A to charge, so you may run into a problem with that. However, iPads and smartphones only use a couple of amps).
4. Remeasure the current in the ground wire in the distribution panel. If you have room to spare within the rating of the ground wire in the distribution panel, you can add the circuits permanently. If you don't, do NOT add the circuits permanently.
5. Consult RVIA for the proper gauging of wires that correspond with different max amperages (i.e. 15A = 14Ga, 20A = 12Ga, 30A = 12Ga).
The distribution panel I believe has a max amperage of 30A for the first 2 circuits and 20A for the remaining circuits, but consult the manual on the distribution panel for verification.
If following the above steps yields that you cannot add the circuits and your unit has 12V accessory sockets, I would use those. If your unit does not have those, I would use a wall adapter on an inverter circuit while dry camping.
wiseguy2315 is offline   Reply With Quote
Old 04-20-2021, 04:14 PM   #3
Thumbs up Adding DC circuits my Interstate
Thanks, wiseguy2315, for the explanation. It was very helpful. I was only adding two small, short circuits for USB connections at the back near the lounge. I ended up running both the loads and the grounds into the load center but could easily could have tapped the white common for the two grounds. I ended up adding a jumper from the white common over to the otherwise unused ground bar for the DC section and attached the two negatives at that point. Either way it works great now that i understand it better.
Old 05-03-2021, 07:54 AM   #4
Wapakoneta , OH
No problem. Just make sure that any work you do, you consult the RVIA standards.
Old 05-03-2021, 03:31 PM   #5
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
If one desires to consults the RVIA standards this link has entire list.
https://www.rvia.org/standards-regul...ansi-standards
You have to pay for all these standards. However those published by NFPA are available to view for free at this link.
https://www.nfpa.org/codes-and-stand...-and-standards
It would be great if all standards organizations would offer their documents for free viewing like NFPA. The free viewer only allows you read, but not copy or download the entire documents. But it is still useful.
This article by Mike Sokol, a well know RV electrical Safety professional is worth reading.
https://www.rvtravel.com/rv-electric...find-out-here/
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 05-03-2021, 05:57 PM   #6
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Given the quality of the wiring I've seen installed by technicians who were allegedly following RVIA standards, I wouldn't worry too much about that specific question. I'd focus more on ensuring a good, safe electrical upgrade that follows proper DC wiring practices.
Adding Circuits AC stranded or solid Tony S Electrical - Systems, Generators, Batteries & Solar 41 12-27-2019 03:48 PM
Lighting Circuits - and 12V circuits in general splyb Lights - Interior & Exterior 9 03-30-2016 07:43 PM
Tracing 12v Circuits, Shorts...First Steps fotochop Batteries, Univolts, Converters & Inverters 27 02-27-2010 07:58 PM
Correct size fuse for 12V circuits FLYNCLD Batteries, Univolts, Converters & Inverters 7 04-23-2009 05:39 PM
12V circuits dmadam Electrical - Systems, Generators, Batteries & Solar 7 04-07-2004 03:03 PM
