Old 03-26-2017, 01:04 PM   #1
2017 Interstate Grand Tour Ext
San Diego , California
Actual Weight 2017 AI EXT Grand Tour
2017 Interstate EXT Grand Tour was weighed 3/24/2017 by SmartWeigh in Tucson, Az. Their scales are periodically calibrated and weights are reported to be within 25 lb. accuracy.
Vehicle when tested.
Fuel 7/8 full: 21 gal. (152 lb. @ 7.1/gal)
Propane 2/3 full: 10 gal. (42.4 lb. @ 4.2/gal)
Fresh water: Full fresh 32 + 6 water heater = 38 gal. (315 lb. @ 8.3/gal)
Black Water: Empty
Gray Water: Empty
Personal articles: Normal items for 3 weeks of camping in Southwest. Nothing heavy. Minimal three season clothes (no winter). 23 lb tools & 15 lb Barbcue are heaviest items. Less than normal groceries & bottled water, etc. No beer.
Weight of 2 people, total weight 310 lb. included in measured weights.
Additional optional installed equipment on vehicle includes AIR SUSPENSION, 2 additional SOLAR PANELS, and 2 additional group 24 AGM BATTERIES on curb side.
LISTED SPECIFICATIONS:
GAWR Front: 4410
GAWR Rear: 7720
CVWR: 11,030 (Note that with both axles loaded to max weights the vehicle would be 1,100 lb over GVWR).
GCWR: 15,250
Height: 9 8
ACTUL MEASUREMENTS:
Front Right Wheel: 1,850
Front Left Wheel: 2,000
Front Axle TotaL: 3,850 (560 lb. under front GAWR).
Rear Right Duals: 3,300
Rear Left Duals: 3,350
Rear Axle Total: 6,650 [/B](1,070 lb. under rear GAWR)
TOTAL VEHICLE WEIGHT: 10,500 (530 lb under GVWR and 4,750 under GCWR. Note that this includes 310 lbs. for 2 people plus tanks & materials as noted above).
Height to top of AC unit: 9 9 (1 in. higher than specification. Air suspension?)
Fly.On is offline   Reply With Quote
Old 03-26-2017, 01:15 PM   #2
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Thanks very much for this.
So pretty well stocked for 3 weeks on the road and still 530lbs under the limit. Very nice!
FlyFishinRVr is offline   Reply With Quote
Old 03-26-2017, 06:24 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
No beer for three weeks . . .
Old 03-26-2017, 07:43 PM   #4
PFFFTT!!!! A full keg weighs about 160lbs. He's got LOTS of room for beer!!!
Old 05-13-2021, 10:39 AM   #5
Aspen , Colorado
Black Water: Empty
Gray Water: Empty
GAWR Front: 4410
GAWR Rear: 7720
GCWR: 15,250
Height: 9 8
ACTUL MEASUREMENTS:
Is tour Interstate a 2500 or 3500? & is it 4x4? I have a 2017 4x4 interatate GT and I'm looking to upgrade the springs and shocks. Currently my van is waiting in line at the dealership because my black tank valve is not functioning, and I would like to get a head start on research for upgrading my suspension, but I can't get my van weighed at the moment.
Bigbettyco is offline   Reply With Quote
Old 05-14-2021, 07:15 PM   #6
Weight & 2 wheel drive
My rig is a 2017 two wheel drive. I have replaced the four AGMs with lithium batteries since then, which reduces rear axel weight by about 200 pounds.
I have had even wear on same-axel wheels but front tires wore out first.
Good luck with the black water valve. I had to replace the macerator but the valves have been behaving nicely. My theory is that going unused does the macerator and valves no good - they may tend to freeze up as will many unused mechanical devices. Now I exercise them monthly when I run the AC for maintenance.
Old 05-15-2021, 11:16 AM   #7
Aspen , Colorado
Good info to know. I like the idea of running systems monthly in the winter months to confirm everything is in working order. My last trip was in February and my black valve froze when temps dropped into the single digits. Or at least that's what i thought because when i parked indoors the value worked again.
I haven't upgraded house batteries yet, but other than 4x4 we are similarly outfitted. I have upgraded to 3 solar panels and carry boxes and a bike rack with 2 e-bike off the hitch.
Front tires wore out well before rears.
2015 Grand Tour Ext bad batteries? Dalwyn Sprinter and B-van Forum 29 10-08-2015 12:14 PM
Interstate Grand Tour EXT Twin Floor Plan TOdehnal Sprinter and B-van Forum 8 07-28-2015 06:18 PM
2015 Airstream Interstate Grand Tour EXT 24 - Florida ineed2golf Airstream Classifieds 0 04-14-2015 07:00 AM
