Old 05-17-2017, 09:53 AM   #1
mrgolf's Avatar
2017 Interstate Grand Tour Ext
Charleston , South Carolina
Access to Sirius XM antenna
I need to alter the mounting of the Sirius SRA-50 flush mounted antenna on our 2017 Grand Tour as it is now blocked partially by a solar panel I mounted. The challenge is getting to the lock nut holding the antenna in place. I've removed the Interstate control panel cover to try to get access from the side, but the angles for reach are not sufficient to unscrew the nut. Once I get access, I can install a 4" pedestal mount that Shakespeare makes for the SRA-50.
My questions then is...how do I carefully remove the felt ceiling piece to provide about 12" of working space directly above the control panel where the antenna is located?
mrgolf is offline   Reply With Quote
Old 07-03-2020, 05:30 PM   #2
Bremerton , Washington
Hi, I was just curious what solution you came up with. Thanks.
PNWnChill is offline   Reply With Quote
Sirius XM antenna adonh Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 08-17-2013 02:51 PM
Routing a XM/Sirius Antenna Wire wolverine Audio, Video & TV 1 05-29-2013 03:29 PM
installing sirius radio in 07 international f b rd tighe Computers, Internet & Satellite 4 09-02-2008 09:48 PM
Adding Sirius to JVC KD-HRD1 on '07 Interstate avid Sprinter and B-van Forum 0 07-16-2008 07:55 PM
Sirius Satellite Radio jordandvm Audio, Video & TV 16 07-13-2005 03:14 PM
