Old 03-26-2023, 05:03 PM   #1
2017 Interstate Grand Tour Ext
Niceville , Destin
A/C Replacement
Just installed the RecPro Houghton quiet air conditioner and a Max air vent, all can say is Wow what a difference. We can now carry a conversation without yelling at each other, even on the highest setting its quieter than the old Dometic and install was pretty easy.
Vacayourway1 is offline   Reply With Quote
Old 03-26-2023, 06:18 PM   #2
2015 Interstate Grand Tour
Salem , New Hampshire
Thanks for posting this info. Do you have a remote control for it exclusively or where they able to tie it into the existing Airstream provided thermostat?
I ask because we installed the MicroAir Easy Touch Thermostat which was a drop in replacement to the Airstream one and we love it as we're able to control the temperature remotely via WI-FI. We lost our dog back in February but are looking to get another one and this is a very important feature for us.
https://www.microair.net/collections...ol-replacement
StogieMan is offline   Reply With Quote
Old 03-26-2023, 07:34 PM   #3
Niceville , Destin
Sorry! But it comes with a remote control and I was unable to use any of the airstream components. I also had to remove and replace the original thermostat as it wired with a Cat5 wire into the old A/C, the new thermostat is a heat only and I had to snake two wires to the heater.
Old 03-31-2023, 03:08 PM   #4
Houston , Texas
Originally Posted by Vacayourway1 View Post
Just installed the RecPro Houghton quiet air conditioner and a Max air vent, all can say is Wow what a difference. We can now carry a conversation without yelling at each other, ...
Ditto for me.
Leigh & Bettie
Houston TX
2017 Interstate GT
TayaraTravel is offline   Reply With Quote
Old 04-03-2023, 02:45 PM   #5
Traverse City , Michigan
To those that have replaced the a/c with the Houghton, did you use the “custom machined roof adapter” between the unit and van roof?
Heckler56 is offline   Reply With Quote
Old 04-03-2023, 03:22 PM   #6
orlik's Avatar
Gulf Breeze , Florida
Mine was installed by Advanced RV and I think I recall an adaptor was used and required for proper fit.
orlik is offline   Reply With Quote
Old 04-04-2023, 09:04 AM   #7
Houston , Texas
Mine was done by a local Houston shop. If you need, I can dig up the work order with the parts.
Leigh & Bettie
Houston TX
2017 Interstate GT
Old 04-06-2023, 06:48 AM   #8
Thank you for the offer but no need to dig out the invoice. All professional shops seem to use an adapter. I know there have been multiple people diy’ing the replacement but very limited posting on details of going diy.
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 05:05 PM
