09-14-2021, 12:35 PM
2019 Interstate 19
San Antonio
7 Gallons of DEF after 2K miles?
New 2020 Sprinter, checked DEF before I left, drove Pennsylvania to Florida. In for other repairs, I asked them to check the DEF. They said it needs 7 gallons of DEF. Does that sound right?
09-14-2021, 12:44 PM
1994 34' Excella
Warren
, Manitoba
Def tank size is about 6.6 gallons!! How full was it when you left home?
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
09-14-2021, 12:48 PM
2024 Interstate 19
Fulton
, Maryland
I would not trust what the shop told you. Only way to know for sure is to fill it yourself and see how much it takes to get back to same level you started trip.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
09-14-2021, 02:28 PM
2013 Interstate Coach
Waterloo
, Iowa
I believe the new Sprinters have a DEF gauge. What level did it show? Were you getting a low DEF warning? I think that comes on with 2.5 gallons left.
09-14-2021, 02:52 PM
2021 Interstate 24GL
San Francisco
drove cross country twice in our 2021 Interstate and the DEF alert went off almost every 3500 miles. had to fill up the DEF fluid 3x. each container was 2.5 gallons I believe.
09-14-2021, 03:35 PM
2019 Atlas
FOOTHILLS
, AB
On my 2018 sprinter there is a tank gauge. I just drove cross country (5600 miles). Started with a full tank and ended with about 1/4 left. My tank capacity is 4.7 gallons
2019 Atlas
09-14-2021, 03:50 PM
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
I'm trying to figure out how they're going to get 7 gallons into a 6 and a half gallon tank, let alone tell you it *needs* 7 gallons (when it can't even hold it!).
09-14-2021, 05:33 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Odd ..... I just got a "tank empty" warning on my F350 after about 3,000 miles towing in the mountains. It slurped up 7 gallons to fill the tank. Was the tank full "as delivered" ? ... anybody got the keys to the Tardis?
09-14-2021, 08:08 PM
1988 32' Excella
Robbinsville
, New Jersey
Maybe they meant 7 quarts?
09-14-2021, 11:01 PM
2018 Interstate Lounge Ext
LV
, Nevada
Mercedes Measures in Metric
Mercedes Sales or Service only talks metric, even in their USA dealerships. It is possible they misspoke -or- you misheard/misunderstood. But regardless, they most likely filled with 7.0 liters = 1.85 gallons. Their AdBlue DEF comes in 1.89 or 10 liter containers (which do have the US gallon conversion value right next to it for the US market).
09-15-2021, 05:56 AM
2020 Interstate 19
Hammondsport
, New York
2019 Sprinter here and we are nearly done with a NY —> CA —> OR —> NY trip (over 6,000 miles) and I had to refill at about the 5,000 mile point.
09-15-2021, 08:58 AM
Waterloo
, Iowa
Zach05855
Your 3/4 tank (3.5 gallon) per 5600 miles is similar to my DEF consumption: 2250 mpg before AEM, 1950 mpg after AEM. Surprised if you were able to get to 1/4 tank (a bit over 1 gallon left) without triggering whatever warning is used on 2018's.
09-15-2021, 09:01 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If it's the real MB item, those 7 liters will cost you pretty close to what 7 gallons will run down at the big box store ....
(yes, AdBlue is a German trademarked term for DEF from multiple suppliers so there may be cheap jugs out there ....).
09-15-2021, 09:24 AM
2019 Atlas
FOOTHILLS
, AB
Originally Posted by Titus
Zach05855
Agreed, it does trigger at around 1/4 tank.
2019 Atlas
09-15-2021, 09:31 AM
2010 25' FB Flying Cloud
Snoqualmie
a little off-topic but If you go to a major truck stop they will have DEF in DEF pumps (typically next to each diesel pump) and the cost is just a fraction of what it costs to buy DEF in the containers. And you can fill up with Diesel at the same time.
09-15-2021, 09:33 AM
palm beach gardens
No, you have a problem.
It is probably one of two things. First, my GMC dealer automatically filled my DEF tank and they only charge for a full tank when i did not need that much.
Second, there is a problem with how much DEF you are using. I was using double what I should have and took to dealer and they said they could not find anything wrong. I drove away and truck continued to use too much fluid. I returned to dealer and told them to figure out the problem and they finally did and fixed it.
Now it uses the proper amount.
09-15-2021, 10:06 AM
2017 23' Flying Cloud
Mesquite
, Nevada
DEF Gouging
Dealerships gouge on DEF, buying it in boxes is slightly better, BEST is getting it from a pump @ a truck stop with commercial truckers.
09-15-2021, 11:06 AM
Here and There
, West Coast
Left side steering wheels control. Upper left corner > Home button. Scroll the display in the gauge cluster to the left using the square button on the steering wheel. Select > Service by depressing the square button. Scroll down to DEF Level. Press the square button again. With some luck the level indication will be accurate. You may also choose to have the DEF level displayed all the time as you drive (settings). Keeping the DEF tank maintained is important for not only avoiding the countdown but preventing crystals from forming in the tank. Best may be to watch the tank and when it hits the one half mark add to fill it up again. Buying a box of DEF is a good idea but large to carry around with you. The stuff should store in the box for a year plus if in reasonable temperature range.
09-15-2021, 11:22 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Well .....
When the messages start popping up about "contaminated DEF, see dealer immediately" and "contaminated DEF, world ending in 21 seconds" and on and on ... the dealer likely wants money to fix the problem. If you have been filling the tank here and there, you really don't have a lot of leverage. If it's all come out of boxes with name brand labels on them, you have bit more (but not a lot) of wiggle room on that charge.
09-15-2021, 12:54 PM
2018 30' Classic
Shawnee
, Kansas
You know, we had two RAM diesels and they both used a fair amount of DEF. The Bighorn was lighter and used less than the Laramie 6.7 Cummins which seemed to use a 2 1/2 gallon box every 750 miles. We never let it get below 50%; because all sorts of nasty things happen if you run it dry--engine stops wherever you by the side of the rode. There may even be an alarm reset, etc., etc. The RAM dealer said to bless California EPA Air regulations; although hopefully, it means a cleaner environment with all the trucks/sprinters on the road.
