Old 04-17-2021, 04:18 PM   #1
2000 25' Safari
Denver , North Carolina
Will 7 inches be enough?
Title was a cheap way to get attention.
I just picked up a rock tamer from Goodwill for $40.00. When mounted on my hitch of my 2500 GMC gasser the passenger side flap is 7 inches from the end of my tailpipe. I seen that there can be an issue with a diesel exhaust being too close, will I be in the same situation? Iíve just put it on to check fitting, clearance , etc. But having second thoughts after measuring the tailpipe to flap. Iíll go to plan B which I havenít researched yet, of changing the tailpipe to vent out the side rather than back. Any real life experience appreciated.
ID:	393380   Click image for larger version
mbubbaca is offline   Reply With Quote
Old 04-17-2021, 04:25 PM   #2
1963 30' Sovereign
Alden , MI
I thought this was a family forum....<clutches pearls>
Scott & Katie
Katherine 27 (Rohan), Christian 25 (Katee), Johannah 23 (Josh), Nicholas 18, Genevieve 16, Matthew 13, Andrew 11, Bonus baby Lillian 5, and Delia the Wonder Dog
wagvan is offline   Reply With Quote
Old 04-17-2021, 05:46 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I would go to an exhaust shop and have the pipe moved to the side. I did that on my Duramax so there would be no problem. Cost me $30.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-17-2021, 07:32 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My tail pipe turns to the side.
Old 04-18-2021, 09:11 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Yep, have the tail pipe turned - have seen tamers with exhaust screens but I would have the pipe turned to the side
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 04-18-2021, 10:52 AM   #6
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I took a straight edge ruler and went around the tailpipe inline with the length axis and marked the mud flap. I used a scroll saw to cut out the elliptical exhaust opening. That was years ago and nothing has borne since then.
guskmg
Old 04-18-2021, 07:33 PM   #7
2017 30' International
Charlotte , North Carolina
I think you want to do something. Mine is about 10-12 inches away and the exhaust has affected the rubber flap. First it has deposited black soot on it, put a bit of a bend in it, and rubber is developed more cracks on that side.
Mine are cheap Amazon flaps so I don't care too much, but next set I'll probably bolt some sheet metal over the rubber.
Also GM gas truck.
Al U. Minium is offline   Reply With Quote
Old 04-18-2021, 07:47 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Get a heat shield
Old 04-18-2021, 08:11 PM   #9
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
You’d be surprised how fast hot exhaust will melt a mud flap just driving a couple of miles in town , ask me how I know .
Turnout the exhaust , cheap and quick at muffler shop .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 04-18-2021, 08:59 PM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
We bought a stainless end deflector to put over our tail pipe. That diverted the flow more to the side and downward.
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 04-18-2021, 10:16 PM   #11
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
Not enough!
Yea I would get a 90į elbow. Your exhaust temp at the manifold is upwards of 1200į when pulling a hill and the cat could heat it again. Donít know how much it would cool by the time it exits the tailpipe but I believe it would burn your flap!
mykytiukr is offline   Reply With Quote
Old 04-25-2021, 09:10 AM   #12
Tim Can Tena
Tin Can Tena's Avatar
1969 31' Sovereign
St Albert , Alberta
There are stainless 4” round exhaust ports available from Rock Tamers that can be easily cut into the rubber mat. I added them on my Dodge Ram
Tin Can Tena is offline   Reply With Quote
Old 04-25-2021, 09:34 AM   #13
2015 25' FB Flying Cloud
Sandy , Utah
Banks, the diesel wizards, makes a kit for this. I put one on my truck and it works great.
rocco52 is offline   Reply With Quote
Old 04-25-2021, 09:37 AM   #14
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Hahahhahahah... Captive header!!!
s1000pre is offline   Reply With Quote
Old 04-25-2021, 11:14 AM   #15
2021 27' Flying Cloud
Scottsdale , Arizona
Rock Tamers makes/sells a metal plate that fits on the back of the flap for the situation you are concerned about.
VinceArenas is offline   Reply With Quote
Old 04-25-2021, 12:40 PM   #16
wingingit's Avatar
2014 27' FB Classic
Lake Havasu , AZ
2019 Duramax here with the shield. This is before I started using them. In short I ended up rotating the flaps as far rearward as I could to get max distance and even with the shield the flap still warped significantly and exhausted melted all the plastic but covers along the top. Still functional but the flap gets hot especially when pulling a grade
Can't modify tailpipe on the newer GM diesels w/out voiding emissions warranty since it's all part of the new/improved diesel emissions crap Click image for larger version
wingingit is offline   Reply With Quote
Old 04-25-2021, 03:02 PM   #17
2015 27' Flying Cloud
Katy , Texas
Heat Shield
I have used the Rock Tamers with their heat shield installed on a 2020 GMC Durmax diesel for 10k miles without any issues. I didnít change the angle of the exhaust.
DED56 is offline   Reply With Quote
Old 04-25-2021, 10:12 PM   #18
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
Lady Lake , Florida
Tailpipe
They do make a exhaust shield that can be added to the rock tamers
Being a gas I don’t believe the side pipe bend modified would be a problem
Life is a Highway is offline   Reply With Quote
Old 04-26-2021, 03:06 PM   #19
Carey Box
2019 30' Classic
2013 25' FB Flying Cloud
Franklin , Tennessee
Ditto the heat shield. Very easy to install. No need to modify the pipe. Comes from Rock Tamers with all hardware.
basicbox is offline   Reply With Quote
Point 03 inches difference tvanwave Wheels, Hubs & Bearings 5 01-09-2012 04:37 PM
Can two more inches make a difference? ROBERTSUNRUS Hitches, Couplers & Balls 19 02-02-2011 10:22 AM
1953 Vintage Airstream Clipper 16 foot 5 inches eBay Watch Airstreams on eBay 0 02-27-2009 01:52 AM
Insurance - When is enough enough Poprivet Insurance & Claims 6 06-27-2007 07:29 PM
