06-16-2020, 07:35 AM
Spruce
, Michigan
What do you do with all the electronics?
I constantly struggle with all the electronics that clutter my center console. We have the rear camera monitor for the trailer, the tire pressure monitor, my smart phone and brake controller. I purchased a off the shelf basket that happens to fit perfectly in the console compartment in our 2019 GMC 3/4 ton truck. I put a foam bottom and used velcro on the back sides of each device to attach them to the sides of the plastic basket. I am not sure if the photo is attached, but the picture I took doesn't show my smart phone because I used it to take the photo, but it fits immediately to the left of the rear camera monitor. All of those devices with the basket fit within the compartment in the console when not using them. Streamlines the mess and keeps everything visible and accessible when necessary. We have the GPS from the phone synched to the scree on the truck so I don't need to look at it on the phone when driving. The tire pressure monitor gives an audible signal if the pressure exceeds certain parameters, but I frequently glance at the rear camera on the trailer to see if traffic is following or backing up behind me or about to pass. i also don't want all of those devises cluttering my dash or obscuring my vision ahead. What do you use?
06-16-2020, 08:08 AM
2016 25' Flying Cloud
Jupiter
I have my phone sitting there, but everything else is displayed through the built in display on my 2020 Silverado.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
06-16-2020, 08:43 AM
Tampa
I decided I didn't want anything stuck to the windshield.
My GPS sits on the dash on a beanbag holder. The GPS is also the monitor for the back up camera. (Garmin RV 770 and BC-30) The TPMS is very important, so that monitor uses a cup holder mount and a Ram arm. The phone is only for entertainment, connected via Bluetooth to the truck radio, so it just lays in the console.
I'm considering running a second GPS, my old one. The RV 770 gave up traffic with the camera, and my old one has a "detour" feature.
It will probably just lay on the console.
06-16-2020, 08:49 AM
2017 30' International
Box Elder
, South Dakota
I made a mount from Lexan that bolts to an articulating arm/mount. That is bolted to a metal cage by a company called Builtright industries (Matt is a great guy) that is designed for the dash tray of Ford F series trucks. I have my rear camera monitor and tire pressure monitor up on the dash when towing (stowed in the arm rest compartment when not). And our cell phones live in the cup holders or pockets. I also wired up an 12v cigarette outlet and a usb plug under the cage so there are no wires dangling over the stock screen
06-16-2020, 09:01 AM
2019 27' Globetrotter
Salem
, Oregon
Regarding the TST tire monitor I just leave it laying on the console in front of the shift lever. It will sound off if the parameters are out of range then you can look at the settings. No need to see it all the time just another distraction.
Dave
06-16-2020, 09:02 AM
2021 25' Globetrotter
Cleveland
, Ohio
What arm/mount is that? Looks like a great solution.
06-16-2020, 09:36 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
We did the ProClip Brackets (proclipsua.com) work perfectly. Got the idea from Airstream Nerds
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
06-16-2020, 10:02 AM
Tampa
Outstanding!
I love creativity.
How do you like the Voyager?
06-16-2020, 10:10 AM
Box Elder
, South Dakota
Thanks. The Voyager is pretty good. The image quality isn’t anything amazing but it’s super helpful to know what’s going on around you/when passing. My buddy has the voyager with the smaller screen and I definitely prefer the larger screen.
06-16-2020, 11:43 AM
2019 27' Tommy Bahama
Midland
, MI
Have you had any problem syncing the Voyager? Mine worked great at the dealer but not since. I think Bluetooth is the problem but frustrating.
06-16-2020, 11:47 AM
Box Elder
, South Dakota
I followed the instructions to pair the monitor and camera and all worked fine. I don’t remember the exact process but remember it’s designed to get power when the running lights are turned on.
06-16-2020, 03:06 PM
2018 30' Classic
Punta Gorda
Great idea
We have a 2018 GMC 3/4 ton so we’ll look for a similar basket. I currently set the rear camera on the far right side of the windshield. One trip and I’ll be trained to look down. Great spot for the tire monitor and phones. My question is, how do I sync my phone gps to the truck screen. My truck has the factory gps that isn’t as accurate as the iPhone. Thanks. Chris
06-16-2020, 04:12 PM
Rynmn
2014 25' FB International
Oceanside
Sync
reading my mind...same question: how do you sync phone GPS to truck screen?
Awesome info!
tks, Ray
06-17-2020, 07:37 AM
New FC 25' Owner
2019 25' Flying Cloud
Richmond
, Virginia
Have everything on the windshield, but not happy with that. Plan on putting a piece of thick plastic in the tray located above the dash in my F-150 XLT. Will use suction cups on that plastic rather than glass.
And for some reason, I got interference between my TPMS and the Voyager rear video camera. I moved the TPMS to the far right side of the windshield (have the Voyager screen mid-windshield) and that solved the problem. Will need to keep the TPMS over there I guess...
06-17-2020, 08:32 AM
Salem
, Oregon
I have a android phone and use the app android auto to sync phone to monitor. Works great.
Dave
06-21-2020, 11:18 AM
1978 Argosy Minuet 6.0 Metre
Hillbilly Hollywood (Nashville)
, Tennessee
How about TURN EM OFF AND PUT EM AWAY when driving?
Easy, Cheap and SAFE!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
06-22-2020, 08:24 PM
McHenry
I just added a TST system before our trip to Colorado and used Velcro to hold the display in place. I prefer to have the Voyager display on the windshield so I don’t have to look down to check it. Just glance at it before changing lanes along with the mirrors and I’m good to go.
Also, I can see the TSP display scroll through the four trailer tires as we go. The RAM has a slot to hold two cell phones, one has wireless battery charging below the radio plus the 12” display is great for navigation. Apple CarPlay/Android Auto lets you split the screen into two cards if you want. Happy with the setup so far.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
06-22-2020, 09:26 PM
1967 17' Caravel
Pocatello
, Idaho
X2
Vivian, the Techno Dinosaur
